  3. Plotting A Line Graph Across Design Points in ACTIMES T...
  • Views 13770
Plotting A Line Graph Across Design Points in ACTIMES Tran
Le Rouret
Le Rouret over 5 years ago
Hello.
I am doing a transient simulation with actimes....at a number of points in the transient simulation I am doing a small signal real and imaginary impedance measurement.
When I come to plot this, "plot all", I get exactly what I want...BUT I want a line graph...not just points....how do I do this ?
Some screen snips attached of setup and plot.
Thanks.
IC6.1.8 ISR 13
    That's a rather inefficient way of doing what you want, because it has to keep re-running the transient analysis for each different ac time you're trying to use. Because of the fact that you're a sweep this way it's ended up with each point being a single point versus the time, and then you have a family of curves. Whilst I could give you a way of handling that, a better solution would be to specify the actimes on the tran analysis form as follows:
    Spectre also supports the start:step:stop syntax for actimes (not sure it's clearly documented anywhere), but this means that you can do this in a single transient, and I think that's exactly what you want!
  • Le Rouret
    Le Rouret over 5 years ago in reply to Andrew Beckett
    Friday afternoon...doh ! Better, thanks
