  3. Dynamic tolerance with Spectre X?
  • Views 14256
smikes
smikes over 5 years ago
Is it possible to dynamically alter the spectre X tolerance in a transient sim?
For APS this can be done by changing the "errpreset" variable between conservative/moderate/liberal.
Spectre X accuracy mode is preset on the command line though with the +preset=vx/lx/mx/ax/cx,
is there a way to change this with a dynamic parameter?
Thanks in advance!
    No. See SPECTRE-17271 warning appears when Dynamic Parameter is used to change errpreset in Spectre X
    This article explains that you can change reltol, but changing the +preset isn't really feasible as that would alter some of the optimisation done to the circuit which would mean a significant topology change during the transient.
