  3. license to run spectre electro-thermal demo
  • Views 13853
jjwwlin
jjwwlin over 5 years ago
HI i am tring to run  demo from
spectre/examples/SpectreThermalAnalysis/powerMOS
using spectre -64 ++aps input.scs
however,  error message indicates license is not avaliable.  btw, standalone spectre is ok. please let me know what specific license feature is required for this demo.
Initializing data base for thermal solver of electrical-thermal
co-simulation...
Warning from spectre at time = 5 ns during transient analysis
`rel-000_myThermal-000_tran_thermal', during Electro Thermal Analysis
`myThermal', during task `MDLControl'.
WARNING (SPECTRE-16824): Reliability simulation iteration 1 terminated
prematurely because of the following error(s):
Fatal error found by spectre at time = 5 ns during transient analysis
FATAL (SPECTRE-209): Cannot run Spectre because the required license could
not be checked out. Check your license server or use the license
queuing feature (+lqtimeout) to wait for the required license to be
available.
    You will need a LegatoTm Reliability Solution license to run this. Please contact your account team.
  • jjwwlin
    jjwwlin over 5 years ago in reply to Andrew Beckett
    Hi Beckett Thanks,
    I have one more question
    When i look at the powerMOS example, the thermal properties is represented by DSPF file.
    I wonder how spectre thermal extractor do the thermal analysis without FEM simulator ?
    Is there some way to extract  thermal network by celsisu then put back into spectre to run the simulation .
    thanks
    Andrew Beckett over 5 years ago in reply to jjwwlin
    Please contact customer support for this question.
