  3. Cadence Virtuoso parametric analysis
  • Views 13078
Guruprasad Hegde
Guruprasad Hegde over 5 years ago
I've been trying to perform parametric analysis for a huge number of points (say 10000) but i am unable to do it as I run into an error saying out of memory.
(Note: My ram size is 8Gb)
  • Guruprasad Hegde
    (Note: My ram size is 8Gb). I am using IC618 cadence virtuoso. How can I go about this problem?
    Thank you
    Guidelines for the Custom IC Design Forum
  • Guruprasad Hegde
    Guruprasad Hegde over 5 years ago in reply to Andrew Beckett
    I am using ADE-L to perform parametric analysis (nested parametric analysis) for a particular circuit. I even tried increasing the storage allocated but i was unable to perform analysis greater than 700 plots. Is there any way to perform simulation without simulation files accumulating the storage space.
    Thank you
    Guru
