  3. Accessing simulation variables in verilog-a without passed...
  • Subscribers 136
  • Views 15389
Accessing simulation variables in verilog-a without passed parameter?
MikeVP
MikeVP over 5 years ago
In Verilog-AMS, I am able to access simulation variables in a module by using:
cds_globals.<name of variable>
I'm trying to keep my design as clean as possible, and I don't want to add a parameter to the veriloga view (the other views do not need a passed parameter).  Is there a way to access simulation variables without passing them as a parameter?  I don't want to use the AMS simulator.
Thanks.
    You can access global parameters (e.g. ADE Design Variables) using:
    (* cds_inherited_parameter *) parameter real rfactor=0.0;
    in the Verilog-A. The magic attribute before the parameter definition marks it as access it from the global parameter rfactor in this case rather than it being passed in.
    Hope that helps!
  • MikeVP
    MikeVP over 5 years ago in reply to Andrew Beckett
    Thank you very much.  I will try.
    Could you kindly point me to the documentation on this?
    Andrew Beckett over 5 years ago in reply to MikeVP
    /path/to/SPECTREinstallation/bin/cdnshelp then search for cds_inherited_parameter
    This is in the Verilog-A Reference manual <SPECTREinstDir>/doc/veriaref/veriaref.pdf
    There's also discussion (and a link to the documentation) in this article.
