  3. Cadence Calculator Function for the difference between the...
  • Views 12698
Cadence Calculator Function for the difference between the abscissa of the intersection of two curves
zzzzzzzzzw
zzzzzzzzzw over 5 years ago
I am running a dc simulation for Schmitt Trigger .
Its voltage transfer characteristic curve is shown in the following figure (the green curve  V=Vout ).And the red curve(V=Vin) has a slope of 1 .
I would like to find the difference between the abscissa of the intersection of two curves, which represents the hysteresis width of the Schmidt trigger.
Then I want to do a Monte Carlo simulation of hysteresis width.
So far I have ymin(abs(v("/vout" ?result "dc")-v("/vin" ?result "dc")))  obviously.
However, ymin(abs(v("/vout" ?result "dc")-v("/vin" ?result "dc")))  is not equal to zero but a very small value .I think it has to do with step size.
Is there a calculator expression for what I want to do?
My virtuoso version is 6.17-64b.
  • zzzzzzzzzw
    zzzzzzzzzw over 4 years ago
    need help!
    ShawnLogan over 4 years ago in reply to zzzzzzzzzw
    Dear zzzzzzzzzw,
    Did you happen to see the SKILL script that Mr. Andrew Beckett provided for creating a list from the waveform of the hysteresis transfer function? His response and his SKILL function is at URL:
    https://community.cadence.com/cadence_technology_forums/f/custom-ic-skill/25049/how-to-calculate-hysteresis-using-ocean-skill-script
    As noted in this post, taking the difference between like x-values of will provide a measure of the hysteresis width that might be used in a set of Monte-Carlo analyses.
    I hope this is somewhat useful for you - or provides some insight at the least!
    Shawn
