  3. accepting 1st subckt definition when there are duplicate...
  • Views 13499
accepting 1st subckt definition when there are duplicate subckts
wignesb
wignesb over 4 years ago
How can I make spectre accept the 1st subckt definition when there are duplicate subckts.
Thank you
    You can't. Spectre can either error out on duplicate subckts, or accept the last. If you want a different duplicate to win, you'd need to reorder the netlist (or reorder the includes) so that the subckt you want is the last-defined.
  • wignesb
    wignesb over 4 years ago in reply to Andrew Beckett
    Thank you. The subckt I want to use is read via the "Simulation Files" form and it is read before the schematic netlist. I assume this cannot be re-ordered right?
    Andrew Beckett over 4 years ago in reply to wignesb
    If you include it via the Stimulus Files field, then it will appear below the netlisted subckts. Given that the stimulus file is pre-processed to do name mapping, I'd suggest that it's a good idea to create an indirect wrapper to stop the real file you want to include being pre-processed.
    So create a file, stimulus.scs with:
    include "fileYouWereOriginallyIncluding.scs"
    and then reference stimulus.scs via the stimulus file on the Simulation Files form (I assume you were doing this via Definition Files before?)
  • wignesb
    Thanks Andrew, very helpful
