  3. Control flow when a return from an expression is nil
  • Views 14857
delgsy
delgsy over 5 years ago
When my cross command fails to cross the threshold, it gives eval err in the result.
I want the test to give default value, i.e., uncalibrated value, so the next test have something to compare with.
Otherwise, all the tests after the one that have fail cross command will gives eval err as well.
This code does not work:
if((cross(v("/VOUT_INV" ?result "dc") 0.6 1 "rising" nil nil nil) - pv("/vref" "value" ?result "variables") == nil) "nil" "not_nil")
I found this. Changing the function with my expression does not work.
    ShawnLogan over 5 years ago +1
    Dear delgsy, delgsy said: When my cross command fails to cross the threshold, it gives eval err in the result. I want the test to give default value, i.e., uncalibrated value, so the next test have something…
    Dear delgsy,
    I believe the reason your ocean/SKILL code does not work is that you are requesting an expression be evaluated using the cross() function as part of your conditional expression. Note that your code is also not consistent with the recommendation Andrew made in the post for which you included the URL.
    Luckily, the correction I believe, is quite straightforward if you have the time and wish to try it. You need to include only the cross() function in your conditional expression as in the following example. Since I do not know what desired "default, uncalibrated value" is, I will use the artificial variable name of "default_value" for it and the resulting value as variable "measured_cross_value" in my example. I hope this makes sense to you delgsy!
    measured_cross_value  = if(cross(v("/VOUT_INV" ?result "dc") 0.6 1 "rising" nil nil nil) default_value cross(v("/VOUT_INV" ?result "dc") 0.6 1 "rising" nil nil nil))
    I hope I understood your question correctly delgsy and this is somewhat useful to you!
    Shawn
    You might be better off using this:
    cross(v("/VOUT_INV" ?result "dc") 0.6 1 "rising" nil nil nil) || 0.0
    as the crossing expression (0.0 might not be the default you want) as this then will always give a result. So then you could do:
    (cross(v("/VOUT_INV" ?result "dc") 0.6 1 "rising" nil nil nil) || 0.0) - pv("/vref" "value" ?result "variables")
    The or operator will work sequentially - so if the left side has a non-nil result, that will be used, but if nil, it will move onto the right side of the or operator.
  • delgsy
    delgsy over 5 years ago in reply to ShawnLogan
    Thanks! it works if I do not include the arithmatic operation.
    Andrew Beckett
    Thanks! I will try it later.
    ShawnLogan over 5 years ago in reply to delgsy
    Dear Delgsy,
    Great!! I was happy to read you have it working! Thank you for letting us know and good luck with your simulations!
    Shawn
