  3. question : standard cell symbol import to virtuoso
  • Replies 10
  • Views 17085
jackkong
jackkong over 5 years ago
I want to import TSMC 65nm standard cell library into virtuoso.
The. SPI file was successfully imported into schematic, but I used xxpwr.v importing symbol, some errors occurred
The following is the error message。
INFO (VERILOGIN-589): Using xmvlog binary for compilation.
ERROR (VERILOGIN-28): Failed to run the xmvlog analyzer because the analyzer binary could not be located.
Either the analyzer binary does not exist in the shell search path or you do
not have the required permissions on the file. Set the correct shell search
path and update the file permissions before running the command again.
ERROR (VERILOGIN-5): Unable to open the specified log file (xmvlog.log) for reading. Either the file does not
exist or you do not have read permission on the file.
INFO (VERILOGIN-206): End of Logfile.
    This is just a matter of not having an XCELIUM release in your UNIX path. See this similar post.
  • jackkong
    jackkong over 5 years ago in reply to Andrew Beckett
    Dear Mr. Andrew,
    Thank you very much for your explanation and your solution suggestion.
    I only have xcelium1809 and added path. Now it seems that it doesn't work
    Andrew Beckett over 5 years ago in reply to jackkong
    What does "it doesn't work" mean? Not really much in the way of details - which IC subversion are you using too?
  • jackkong
    The file name of its software is xcelium1809s010, I don't know what version it is.I added three paths:
    export PATH=$PATH:/home/Cadence/SPECTRE181ISR12/tools/bin
    export PATH=$PATH:/home/Cadence/SPECTRE181ISR12/tools/mmsim/bin
    export path=$PATH:/home/Cadence/XCELIUM1809s010/tools.lnx86/bin
    but it still has the same problem. I guess it may be the version problem
    What do you get if you type "xmvlog -version" at the UNIX prompt (I also assume you restarted Virtuoso after you changed the path)?
  • jackkong
    I get"TOOL: xmvlog 18.09-s010".
    And the IC sub-version you're using? Help->About will tell you this (or typing getVersion(t) in the CIW).
  • jackkong
    I get "sub-version  IC6.1.8-64b.500.6 " from CIW.
  • jackkong
    I get "sub-version  IC6.1.8-64b.500.6 "from CIW.
  • jackkong
    jackkong over 4 years ago in reply to Andrew Beckett
    Thank you for your enthusiastic answer. I went back to check the. Bashrc file again. After updating the. Bashrc file, it can work normally. It may be that the path of other software is not set properly, which is not the problem of xcelium.
