  3. PSpice model Editor in Spectre and Virtuoso
  • Views 11441
mjab
mjab over 4 years ago
Hi All,
Is there a PSpice model editor is available in the Spectre or Virtuoso to create a model library?
    No. That would be rather odd, since PSPICE is normally used for board design. There is support for using PSPICE models within Spectre (there's a pspice viewType in Virtuoso, and ADE has the ability to…
    No. That would be rather odd, since PSPICE is normally used for board design. There is support for using PSPICE models within Spectre (there's a pspice viewType in Virtuoso, and ADE has the ability to include pspice model files) but this is normally used for interfacing from a custom IC design (e.g. an analog IC design) to an external component on the board; you wouldn't normally author those PSPICE models within Virtuoso.
    If you're asking about creating behavioural models for blocks in an IC, that would normally be done with Verilog-A or Verilog-AMS (or SystemVerilog or VHDL if it was a high enough level model).
