  3. Verilog-A Parser shows an error but simulation runs successfully...
  • Views 15630
Verilog-A Parser shows an error but simulation runs successfully with 0 errors
ElZorro
ElZorro over 4 years ago
Hello All,
I am trying to use the genvar in a loop.
I am able to run a simulation using the following command: spectre testbench.scs
The results of the simulation are as expected.
The problem/confusion is that I always use the Spectre Syntax Checker (Verilog-A Parser) before running a simulation and in this case it shows an error:
spectre #dpl /dev/null #ahdlfile module_09.va
Error found by spectre during AHDL compile.
ERROR (VACOMP-1191): "module_09.va", line 46: The node array access is out of range. Correct the problem and try again.
Line 46:
V(out[i]) <+ transition(value[i], td, tt);
As I mentioned at the beginning the spectre simulations completes with 0 errors and the results are as expected.
What am I missing in the Spectre Syntax Checker command? I would like to continue using it to check the correct syntax, but in this case it is not working properly.
If I should provide more info, plese let me know.
Additional info:
spectre -W
sub-version 17.1.0.515.isr12
Thank you!
See Verilog-A code below.
`include "constants.vams"
`include "disciplines.vams"
module dut (out, in);
// Parameters
parameter integer width = 8;
// Port Direction
output [width-1:0] out;
input [width-1:0] in;
// Port Type/Discipline
electrical [width-1:0] out;
electrical [width-1:0] in;
parameter real td = 0;
parameter real tt = 1n;
real value [3:0];
genvar i;
analog begin
@(initial_step) begin
value[3] = 3.5;
value[2] = 2.6;
value[1] = 1.7;
value[0] = 0.8;
end
for (i=0; i<=3; i=i+1) begin
end
end
endmodule
    This is an aspect of the fact that Virtuoso doesn't really directly support variable width buses (either in schematics or in Verilog-A models). In older versions of Spectre, the analyser gave errors such…
    This is an aspect of the fact that Virtuoso doesn't really directly support variable width buses (either in schematics or in Verilog-A models). In older versions of Spectre, the analyser gave errors such as you were seeing. These went away in Spectre18.1 ISR12, but then you hit a different problem that both the shadow database used to store the terminal information, plus any generated symbols end up with the wrong bus width (not even the default value).
    A workaround is to use the approach covered in my article How to create a VerilogA model of a DAC with a variable width bus input
  • ElZorro
    ElZorro over 4 years ago in reply to Andrew Beckett
    Thank you for your fast reply Andrew. I will have a look at the provided link.
    Just as a comment or for documentation purposes (I was preparing this before you replied):
    In the example above I wanted to use an Analog Contribution inside the for loop to pass values only to some indexes of the port, in this case to indexes 0 to 3.
    Well, it seems that the Verilog-A Parser doesn't like it and shows an error.
    I would have expected a Warning, not an error because as mentioned in the initial message the simulation runs without problems.
    I did some changes in the code so that I pass values to all the indexes of the port, from 0 to 7, and now the Verilog-A Parser doesn't complain.
    But this is not necessarily what I wanted to do.
    Thank you very much!
    See new code below:
    // Parameters
    // Port Direction
    //~ real value [3:0];
    real value [width-1:0];
    genvar i;
    analog begin
    value[7] = 7.8;
    value[6] = 6.8;
    value[5] = 5.8;
    value[4] = 4.8;
    value[3] = 3.5;
    value[2] = 2.6;
    value[1] = 1.7;
    value[0] = 0.8;
    end
    //~ for (i=0; i<=3; i=i+1) begin
    for (i=0; i<width; i=i+1) begin
    end
    end
    endmodule
