  3. is there a way to change the design for multiple tests simultaneously...
  • Views 11324
is there a way to change the design for multiple tests simultaneously?
delgsy
delgsy over 4 years ago
clicking RMB on the tests and choosing the design is the way I do it.
But this way, I need change the design one by one.
selecting multiple tests and change the design does not work.
    Yes, but you need to be using IC6.1.8 ISR14 or later. See How to modify the design in multiple tests simultaneously in Virtuoso ADE Assembler For other settings (e.g. analysis settings) there's the Tools…
    For other settings (e.g. analysis settings) there's the Tools->Multi-Test Editor which was added in IC6.1.8 ISR4.
  • delgsy
    delgsy over 4 years ago in reply to Andrew Beckett
    Thank you very much for the quick answer.
