  3. ignore instance by layout extraction
  • Subscribers 136
  • Views 13942
Senan
Senan over 4 years ago
I use the  iprobe that break the feedback loop of the amplifier in my design to perform the stability analyses,
Now I am doing the layout, but don't know how to make the iprobe ignored by the layout so I can pass the LVS, then later I will be able to use this probe for my post-layout simulation.
I use the Cadence Virtuoso version IC6.18-64b.500.6 with Assura package
Thank you in advance
Best Regards
    How to perform a stability (stb) analysis on a loop within an extracted view or DSPF file
  • Senan
    Senan over 4 years ago in reply to Andrew Beckett
    Thank you very much Andrew for your help, I will study the link you shared
  • drdanmc
    drdanmc over 4 years ago
    Another way to do it is create a stability cell.  The schematic and layout view are a metal resistor placed per the solution that Andrew linked.  Include a second schematic view called something like `schematic_stb` or something.  When running LVS blackbox that cell and you can then use the hierarchy editor to select the `schematic_stb` view for it.  Yet another way to do it is use a custom QRC `avExtractedCellViewCallProc` function that does the replacement of the metal resistor directly during extracted view creation.  If you try the last way just be aware that it will take some amount of SKILL programming.  I tend to prefer the blackbox approach.
  • drdanmc
    drdanmc over 4 years ago in reply to drdanmc
    I seem to have omitted that the `schematic_stb` view has the `iprobe` instance.
