  3. The generated datasheet is (almost) empty
  • Views 10555
delgsy
delgsy over 4 years ago
I posted the same issue here before using 6.1.8.
Now I am still having the same problem, i.e., almost empty datasheet, in 6.1.8.
The generated datasheet (xml file) only contains the list of model files.
I would like to hear some suggestion that I can try.
    This is probably this: Datasheets in ADE XL, Explorer, and Assembler and Schematics exported to HTML only show limited text or are displayed as a blank page
  • delgsy
    delgsy over 4 years ago in reply to Andrew Beckett
    It works!
    Thank you!
