  3. probe a structure for all layout layers used in its build...
  • Views 11709
probe a structure for all layout layers used in its build?
kenc184
kenc184 over 4 years ago
Is it possible to select a structure - in my case a fluid guard ring - and display every layer used in its  construction?
    Assuming it's an instance (which a fluid guard ring is), then:
    inst=car(geGetSelSet())
    foreach(mapcar lpp inst~>master~>lpps list(lpp~>layerName lpp~>purpose))
    The second outputs a list of layer-purpose pairs used within the instance (including down in the hierarchy).
  • mctang21
    mctang21 over 4 years ago
    You could try moving the cursor to the instance and enter bindkey "t" .  Does it serve your purpose ?
  • kenc184
    kenc184 over 4 years ago in reply to mctang21
    Thank you both.  In this case, mctang21s quick solution is perfect.  I will fiddle around with Andrew's solution also.
    Andrew Beckett over 4 years ago in reply to kenc184
    If you'd just wanted the layers underneath the cursor (which is not what you said), I'd have also suggested using WIndow->Assistants->Dynamic Selection. You can then move your cursor and see all the layers under a point (and you can freeze/unfreeze the display so you can then move the cursor afterwards - there's a hint for the bind key to use at the bottom of the dynamic selection assistant).
  • kenc184
    kenc184 over 4 years ago in reply to Andrew Beckett
    I had glossed over that feature, but it looks quite handy. Thanks for the info.
