  3. Simulating Config with veriloga view set, does not simulate...
  • Replies 12
  • Views 21009
Simulating Config with veriloga view set, does not simulate the veriloga version but still runs the schematic.
JohnTweed
JohnTweed over 4 years ago
Spectre 17.1.0
Virtuoso 6.1.8
Been away from Cadence for a few years, but now I'm back,  and as usual, nothing is simple.
I have a top level schematic,  calling one instance to test, driven by various analoglib sources.
I have a schematic, symbol and veriloga view of the instance DUT.
I have a config view of the testbench.  In the config,  I've set the view list order so that verloga comes before schematic.  The config then sets DUT to be veriloga view.
That's all as expected.
But now with ADL and selecting 'design' as the config view,  I expect the netlister to give me a netlist with the instance and an ahdl_include to the path to the verloga.
What I get is a netlist with the DUT schematic netlisted. So it's ignoring the hierarchy config.
So what do I need to do to get this to 'just work' as I expect?
Ie,  expected outcome is that 'Netlist &Run'  respected the config, generates the correct netlist and runs the simulation.
If I go to the original run / netlist dir and edit  input.scs, take out the DUT schematic subckt definition, add in the ahdl_include to the VA path....
Then ./runSimulation then it runs correctly.
I shouldn't need to do this should I?  But what do I need to do, that means that the netlister will do the ahdl_include  etc for me?
    That's very odd and should not be necessary. I'm rather surprised that you're seeing this because this should be robust and I've not seen this elsewhere (other than some user mistake where the design was really not set to be the config, or there was a mistake in the config).
    Can you contact customer support please? That's going to be the fastest way of seeing what is going on and identifying how to fix it.
    ShawnLogan over 4 years ago in reply to Andrew Beckett
    Dear JohnTweed,
    If I may add a possibility, that of course Andrew's suggestion would cover with you. Are you sure you selected the "config" view when you selected the design for the Assembler or Explorer test? I know this has happened to me occasionally when I find the desired config view is not selected in the netlist created b Assembler and Explorer.
    Specifically, as shown in Figure 1 where the I show how to select the design for a test, in the subsequent dialog box (Figure 2), one can select its "schematic" or its "config" view. I thought I would at least check that your test has "config" selected and not 'schematic".
    Shawn
    Figure 1
    Figure 2
  • JohnTweed
    JohnTweed over 4 years ago in reply to Andrew Beckett
    Thanks Andrew, Shawn.
    To be honest I don't think I've ever had this running without issues,  so I must be doing something odd.
    It all worked perfectly with AMS, but not with Spectre/ADL/Veriloga,  I think (though it's now 3 years ago) that I always had to manually insert the path to the VA file for spectre simulations.
    As far as I remember, the problem only ever occurred when there's a schematic too.  When there's only a veriloga and symbol, I think it worked OK.  But that's the whole point of incremental design,  being able to switch views to see how the design deviates from the 'ideal'.
    As you say Andrew, it should just work, I'm not sure what I do that's messing it all up.
    @Shawn, yes I've checked...(FYI, I've been using Cadence tools since 1990, but of course we still make mistakes, so it's worth repeating the obvious).
    In the run.log I see this for the run.
    Simulating `input.scs' on server at 11:03:42 AM, Thur Mar 31, 2022 (process id: 300).
    Current working directory: xxx/cds_sim/MySimBenches/test_lvlsh/spectre/config_va/netlist
    Command line:
    /tools/external/cadence/spectre/17/17.10.389/tools.lnx86/bin/spectre \
    -64 input.scs +escchars +log ../psf/spectre.out -format psfxl \
    +rtsf -raw ../psf ++aps +lqtimeout 900 -maxw 5 -maxn 5 +lorder \
    MMSIM +lqt 0 +lqs 30 +lsuspend +lqmmtoken
    But the netlist still shows ...
    // Library name: __tmpLib
    // Cell name: itrx_can_vss_lvlshft
    // View name: __tmpView
    // Inherited view list: spectre veriloga cmos_sch cmos.sch schematic ahdl
    // pspice dspf
    subckt itrx_can_vss_lvlshft IN BYP OUT OUT_n SUB VDD VSD VDP VSP
    MN10 (VSD inp VDD inn VSD SUB) nmos_5p0_dw_6T_pcell_0 \
    pf1va_width=3.460u pf1va_length=2.045u mx=1 dnw_width=9.460u \
    dnw_length=8.045u fingerW=845.000n nf=2 l=600n sArea=0.5746p \
    So still net listing the schematic.
    @Andrew,
    Not sure how easy it is for me to use Cadence Support, since I'm on a temporary placement at the company.
    So I've not got anything set up for Cadence support just now.
  • JohnTweed
    JohnTweed over 4 years ago in reply to JohnTweed
    Sorry.  The config view should have been..
    ShawnLogan over 4 years ago in reply to JohnTweed
    Dear JohnTweed,
    Why is your view list starting with the "spectre" view? I usually place the "spectre" view as the last view to examine as it is the stopping point for views.
    In other words, move the "spectre" to after, for example "schemaic". Have you tried that?
    Shawn
  • JohnTweed
    JohnTweed over 4 years ago in reply to ShawnLogan
    That is how the Spectre Template populates the View List.
    I think that the ordering of Spectre & Schematic will only disrupt special cases where you have a model and a schematic view together. But then, that is what I have here, except my 'model' is a veriloga file.  The main difference however, is that models are imported in a model library file.
    But, it's worth a try.
    I'll get back to you tomorrow.
    Andrew Beckett over 4 years ago in reply to JohnTweed
    Thanks for including the netist - I spotted that it looked rather strange and was showing __tmpLib and __tmpView as the library and view names in the comments which allowed me to search and I found that there is an experimental feature (which has not been released and has a number of problems) which was added for one customer in particular (given their location in the world I suspect it's not that company you're at, so not sure why the setting has been enabled there). Anyway, I believe you have the variable:
    hnlUseSchematicForInherittedConnection
    set to t (yes, there's a spelling mistake in the variable name). This variable should not be used - it was specifically to deal with a requirement related to inherited connections with the Verilog netlister and clearly breaks the spectre netlister (I'll report this to R&D, but they will undoubtedly ask me why it is being set in the first place).
    Try setting:
    hnlUseSchematicForInherittedConnection=nil
    and then recreating the netlist - see if that fixes it. You should ask within your company why this is being set and get them to contact us about it.
    At least I hope this is the reason. I was able to reproduce the problem by setting the variable...
    Andrew Beckett over 4 years ago in reply to Andrew Beckett
    Oh and having spectre at the beginning of the viewList is perfectly fine - it would only make a difference if you have a spectre view and one of the other views, and even then it would depend upon your preference as to which should be picked by default. It can't affect this.
  • JohnTweed
    Thanks Andrew for your (always) helpful responses,
    Will try that later today and report back.
    If it works, I'll get someone in my company to check the setting.
  • JohnTweed
    Sorry, but no luck with that.
    First I tried checking that hnlUseSchematicForInherittedConnection variable and Cadence responded with 'variable not set'
    I set it anyway in my .cdsinit (along with a print, to be sure).
    But no luck,  still the same result, that it's the schematic version.
    Here's the relevant bit of the CDS.log for the simulation.
    \a sevNetlistAndRun('sevSession1)
    \o Delete psf data in /local/users/user/cds_sim/MySimBenches/test_lvlsh/spectre/config_va/psf.
    \o generate netlist...
    \o Loading seCore.cxt
    \o Begin Incremental Netlisting Apr 1 07:53:30 2022
    \o {07:53:30} (IPC command) "svn --config-dir=/bach/users/user/.methodics/versic/subversion info --non-interactive /local/users/user/workspaces/project/trunk/cds_run/__tmpLib" [log:/tmp/user-versic/vscIPC_15399_bi]
    \o {07:53:32} (system call) "find /local/users/user/workspaces/project/trunk/cds_run/__tmpLib -name .svn | xargs rm -rf"
    \w *WARNING* (DB-260008): dbOpenBag: Fail to open prop. bag for '__tmpLib' in 'r' mode, file not found
    \w *WARNING* (DB-260005): dbCloseBag: Invalid bagID - nil
    \o INFO (TECH-1000002): Attaching default techfile (cdsDefTechLib) to library __tmpLib.
    \o WARNING (OSSHNL-169): The property bag for the library '__tmpLib', has been modified or added since the
    \o last netlisting session. Therefore, re-netlisting all the cell views used from
    \o this library as well as all the cell views where instances of cell views from
    \o this library are used.
    \o
    \o End netlisting Apr 1 07:53:34 2022
    \w *WARNING* ddStartGenObjRel: argument must be Lib, Cell or View; found ddViewFileType.
    \o Loading monte.cxt
    \o
    \o Netlisting Statistics:
    \o Number of components: 19
    \o
    \o Elapsed time: 7.0s (2.71/s)
    \o Errors: 0 Warnings: 0
    \o ...successful.
    \o compose simulator input file...
    \o ...successful.
    \o start simulator if needed...
    \o ...successful.
    \o simulate...
    Just to be sure it's not me :-)...  I closed the ADL,  reopen ADL again with the design=config_va, but this time as an AMS simulation. Reload the spectre state for the tran settings, models etc.
    The Netlist&run AMS.
    Works exactly as it says on the box...
    But for now I suppose, every time I want to try something out with veriloga in place of the schematic I can just run AMS.  It's a work around, but I'm not supposed to be spending much time on this.
    I'll ask one of my full-time colleagues to also try this to see if they also experience this issue.  If they do, then they can initiate the conversation with Cadence Support.
    Andrew, it seems that this is too opaque to be handled within the forum.  So it'll have to wait till someone has time to address it.
    Thanks for your suggestion.
