  3. Layout Dummy filling using Assura in Cadence Virtuoso
  • Views 14364
Senan
Senan over 4 years ago
I am using Assura tools in Cadence Virtuoso, I would like to ask how to make the dummy filling at the end of the layout design, where I can run it.
Thank you
Best Regards
    Running Fill with Assura is typically running DRC and picking a rule deck specifically to do fill. This may be defined in the techRuleSets within the rule directory referenced by your assura_tech.lib file…
    Andrew Beckett over 4 years ago in reply to Senan +1
    Senan said: I couldn't find the option of FILL from Assura, can you please help me in this As I said before: Andrew Beckett said: You should consult the PDK or DRC/FILL documentation for the technology…
    Running Fill with Assura is typically running DRC and picking a rule deck specifically to do fill. This may be defined in the techRuleSets within the rule directory referenced by your assura_tech.lib file - but this is going to be specific to the PDK you're using. You should consult the PDK or DRC/FILL documentation for the technology you're using.
  • Senan
    Senan over 4 years ago in reply to Andrew Beckett
    Thank you Andrew for your reply,
    Regards
    As I said before:
    If you can't find that, contact the foundry or whoever provided the PDK. If Fill is necessary, they ought to tell you how to access the rules!
  • Senan
    Thank you, Andrew,
    you are right, I have contacted the foundry, they  have their own procedure for this step and they informed it about it.
    Regards
