  3. How to use save/restore feature with 1st run result
  • Views 2276
ichiro
ichiro over 4 years ago
Hi all,
I found a usage of "save and restore" in ADE as below.
https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1Od0000000nSpJEAU&pageName=ArticleContent
1st run: 0 - 10ms, saved at 10ms
2nd run: 10ms - 20ms using "***_at_10ms file"
Then the result included only 2nd run result.
Is it able to display/calculate a combined two run results as one waveform?
regards,
Ichiro
    ShawnLogan over 4 years ago +1
    Dear Ichiro, ichiro said: Is it able to display/calculate a combined two run results as one waveform? Did you happen to read the following On-line support article describing two ways to combine transient…
    Dear Ichiro,
    Did you happen to read the following On-line support article describing two ways to combine transient simulation runs?
    https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1Od0000000nVzkEAE&pageName=ArticleContent
    This second method might also be useful using the calculator to combine the results of a waveform from two simulation runs:
    https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1Od0000000nVaeEAE&pageName=ArticleContent
    Shawn
  • ichiro
    ichiro over 4 years ago in reply to ShawnLogan
    Dear Shawn,
    Thanks for great information! I'll try the way of combining two psf.
    Ichiro
    ShawnLogan over 4 years ago in reply to ichiro
    Dear ichiro,
    You are MOST welcome and good luck! I am just happy to read the information provided some thoughts to help you solve your problem!
    Shawn
