  3. How do I open F3 options windows in center monitor on a...
  • Views 11106
How do I open F3 options windows in center monitor on a multi-monitor system?
dietSprunk
dietSprunk over 4 years ago
Currently I'm using Cadence Virtuoso XL on laptop that's running three monitors.  The monitors are setup from left-to-right.  The left-side monitor is the tiny laptop monitor that I use for email-only.  The center monitor I use for my VXL layout view window and the CIW.  The right-side monitor I use for the schematic view window.  However, when I open any of the "F3 options" windows for various layout commands, (stretch, copy, move, etc...) the pop-up window always appears on the left-side monitor.
How do I get these windows to start showing up in the center monitor when I press F3?
  • Alex Soyer
    Alex Soyer over 4 years ago +1
    Hello, Have you tried this solution? https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1Od0000000nXCGEA2&pageName=ArticleContent&oMenu=People%20who%20viewed%20this%20also%20viewed Please…
  • Alex Soyer
    Please let us know if it helps or not.
    Alex
  • dietSprunk
    dietSprunk over 4 years ago in reply to Alex Soyer
    Thank you for the help.  I found the problem was in the settings of my VDI software and not Cadence.
    Problem solved.
