  3. Using the same output expressions for post-layout simul...
  • Views 11328
Using the same output expressions for post-layout simulation
delgsy
delgsy over 4 years ago
Previously, I worked on smaller circuits and never had any need to probe inner nodes, just characterized the circuit performance from the output pins.
Now, I want to probe inner nodes and use the same output expressions for post-layout simulation.
I almost always use "expr" type for the outputs.
From here[1] and here[2], it seems that I need to create .simrc file.
But still cannot make it works.
In order to be sure, now I am doing Lab3 section from here[2], it shows that outputs with type "signal" and "expr" work well.
But that is not the case when I try it. I cannot make output with the type "expr" works.
This is actually my original problem.
Modification of .simrc for "signal" type of outputs is explained in here[1],  but not the ones with "expr" type.
did I miss anything here?
Again, my main target is using the same output expressions both for pre- and post-layout simulation.
If there is another way to achieve this other than what has been explained in here[1] and here[2],I would like to be informed.
    Please contact customer support for this. There are some newer flows which aim to make this simpler without needing .simrc modifications.
  • delgsy
    delgsy over 4 years ago in reply to Andrew Beckett
    Thank you for your quick reply.
    I do not have access to contact the customer support.
    If there has been documentation for this new flow, I would like to know.
    Thanks again.
    Andrew Beckett over 4 years ago in reply to delgsy
    If you're at an academic institution, then if you have access through Europractice, ask them for support. Otherwise you can get your University program owner to log a case on your behalf.
    The challenge is that I'm not sure the new flow is widely available yet, so I don't think there's public documentation or a rapid-adoption kit on it. I have a quick start guide, but it's not something I can share here.
    So maybe I'm premature in suggesting the new flow.
