  3. How to change pin size in an existing symbol?
  • Views 16378
StephanWeber
StephanWeber over 4 years ago
in all my symbols, and also in analogLib, we have pins drawn as a small red rectangle. However, a more beautiful solution would be to have even smaller rectangles, like 25% of the standard size. By experimenting I was able on the placement of a pin to get indeed (and surprisingly) a very small circular pin, which looks very nice. However, I was not able to now modify all my existing pins to get exactly this better style. In the Edit Property dialog I found no way to do it. Is there a hidden trick?
Bye Stephan
    Stephan,
    The edit properties doesn't have a way to change the pin shape from one to another, but it can be easily achieved with SKILL. Not sure this would particularly help you with analogLib since that's a library shipped with Virtuoso, but anyway here's some code I just threw together to change all the pins in a symbol from square to the small round pins you liked.
    /* abChangeSymbolPinsToRound.il
    Author     A.D.Beckett
    Language   SKILL
    Date       Apr 13, 2022
    Modified
    By
    Function to change all pins on a symbol to be round
    rather than the usual square pins
    abChangeSymbolPinsToRound()
    SCCS Info: @(#) abChangeSymbolPinsToRound.il 04/13/22.20:40:56 1.1
    *    abChangeSymbolPinsToRound([?cvId geGetEditCellView()]     *
    *                      [?radius 0.00625])                      *
    *  Change all rectangular/square pins on a symbol to be round  *
    *   pins. Both the cvId and radius can be passed as keyword    *
    *              arguments to override the default.              *
    procedure(abChangeSymbolPinsToRound(@key (cvId geGetEditCellView())
        (radius 0.00625))
      let((newPinFig)
        foreach(term cvId~>terminals
          foreach(pin term~>pins
            foreach(fig pin~>figs
              when(fig~>objType=="rect"
                destructuringBind((x y) centerBox(fig~>bBox)
                  newPinFig=dbCreateEllipse(
                    cvId fig~>lpp list(x-radius:y-radius x+radius:y+radius)
                  dbAddFigToPin(pin newPinFig)
                  foreach(child fig~>children
                    child~>parent=newPinFig
                  dbDeleteObject(fig)
        t
  • StephanWeber
    StephanWeber over 4 years ago in reply to Andrew Beckett
    many thanks for this code, it works fine!
    I only tried to make an extension to run this on a whole library:
    procedure(changeSymbolPinSizeLib(libN)
    let((libId cvId)
    libId = ddGetObj(libN)
    foreach(cellN libId~>cells~>name
    when(dbOpenCellView( libN cellN "symbol")
    cvId = dbOpenCellViewByType( libN cellN "symbol" "" "a")
    dbSave(cvId)
    dbClose(cvId)
    ); ** when **
    ); ** foreach cell **
    Unfortunately I do not see that it works. It loops across all cells, but gives error messages, so that the old big pins are still present.
    Do you see a mistake in the code?
    Bye Stephan
    Andrew Beckett over 4 years ago in reply to StephanWeber
    Yes, you are not passing the cellView id to abChangeSymbolPinsToRound(), so it would be always editing whatever cellView is in the current window. You would need to call:
    abChangeSymbolPinsToRound(cvId)
  • StephanWeber
    Thanks, again, Andrew! But I still fail with this code:
    let((libId cvId)
    dbSave(cvId)
    dbClose(cvId)
    ); ** when **
    I get this:
    *Error* abChangeSymbolPinsToRound: extra arguments or keyword missing - (db:0x8c8e4f9a)
    Do you see again, what is wrong?
    Bye Stephan
    Stephan,
    My mistake. I didn't read my own code. The argument is a keyword rather than positional argument. The line should be:
    abChangeSymbolPinsToRound(?cvId cvId)
  • StephanWeber
    Many thanks, Andrew. Now it works fine.
