  3. follow up with find the location of a variable in schem...
  • Views 10497
follow up with find the location of a variable in schematic
monglebest2022
monglebest2022 over 4 years ago
https://community.cadence.com/cadence_technology_forums/f/custom-ic-design/19688/find-the-location-of-a-variable-location
I want to follow up with this question 10 years ago. May I ask if the schematic has the feature now to find the instance for a certain variable used?
I know there is a option in maestro to right click the variable and ask it to identify the instances in schematic, but I wonder if schematic alone can support this feature or not after 10 years?
For example, can I do Edit->Find in schematic to show the same lists of instances for a certain variable used?
    Since ADE is the primary tool that uses design variables, the capability to search for design variables used in expressions on components remains within ADE.
