  3. QRC Configuration options in PVS
  • Views 12159
Senan
Senan over 4 years ago
I am using the PVS version 19.10 on Cadence Virtuoso IC.18-64b.500.6
I would like to ask how to ask where to activate the following options
. Floating Gate
. Floating Well
. Extract parasitic diodes as LVS diodes
Those options were available in the PVS version 15.23-64b but I can not see them on PVS 19.10
By the way, I see that Cadence are encouraging to use the PVS tools over the other tools like  Assura...etc, is this because it is a Cadence product or it is really more accurate tools.
Thank you in advance for your help
Best Regards
Best Regards
    Andrew Beckett over 4 years ago in reply to Senan +1
    OK, this is not related to the tool itself or the version, but something in your technology setup. The "Configurator" is a way to add UI options for PVS, and usually this would be referred to from the…
    I'm not sure what these first three options are you're talking about. I looked back at an old PVS version and didn't see them nor did I see anything quite like them when doing some searching. Can you show a screenshot of where these options were before in the UI?
    Both PVS and Assura are Cadence products. However, PVS has active development whereas Assura is quite an old tool - so it's really about ensuring you're using modern technology which has active development. Physical verification tools tend to have very long life cycles, but I would say that most foundries are moving away from Assura support to PVS and Pegasus.
  • Senan
    Senan over 4 years ago in reply to Andrew Beckett
    Dear Andrew,
    Thank you very much for your answer and your nice explanation regarding the importance of the PVS tools as compared to Assura, that fulfill my inquiry.
    With regards to the options in PVS I asked (Floating Gate,  Floating Well,  Extract parasitic diodes as LVS diodes ), I have took you a screen shot showing these options available in PVS 15.23
    Thank you once again
    Best Regards
    OK, this is not related to the tool itself or the version, but something in your technology setup. The "Configurator" is a way to add UI options for PVS, and usually this would be referred to from the techRuleSets file - there would be an entry called lvsGuiPreset which would refer to a PVS configurator file which will define the options to show own this form.
    Presumably something is different in the setup of the technology data for PVS between the two versions that you're using. As I said, that's not a tool version problem but an environment setup problem.
    If you can't get this working, please contact customer support - it's going to be hard to guess what is or isn't working without knowledge of the technology and/or seeing your environment.
  • Senan
    Dear Andrew,
    I am grateful to you for your clear answer and help support,
    You made it clear for me, so I will contact my foundry tech team to add these configuration setting into my PVS setting
    Best Regards
