  3. Writing into a file in Verilog-A Model
  • Views 10908
Ketrin
Ketrin over 4 years ago
Dear All,
I want to write the data into a file in the Verilog-A model.
I tried something like below.  It is not showing any errors, but the file is still empty. By the way, reading from this file works great.
`include "constants.vams"
`include "disciplines.vams"
integer fd;
real r_file = 0.001;
analog begin fd = $fopen("./my_file.txt", "w");
$fwrite(fd, "%e", r_file);
//outp = $fscanf(fd, "%e", r_file);
$fclose(fd);
end
endmodule
I also tried $fdisplay but the result didn't change.
    This works for me. It will write the file into the netlist directory (if used with ADE). It's going to write a file at each iteration which is almost certainly not what you want, but it does write each time. I added the missing module definition (was missing in your example):
    module forum146;
    integer fd;
    //$debug("written again\n");
    $fclose(fd);
    end
    endmodule
  • Ketrin
    Ketrin over 4 years ago in reply to Andrew Beckett
    Thanks! I've added the check loop, so it doesn't write a file at each iteration now.
