  3. How to stop Ocean script from UINX
  • Views 10793
mgkang
mgkang over 4 years ago
Hello.
I`m using IC6.1.8
This simulation is just "sweepsAndCorners" and There are lots points
I found the problem. so I try to stop script while script is working
How to stop Ocean script from UINX?
I ran the script like this
> ocean -restore test.ocn
Thank you.
    ShawnLogan over 4 years ago
    Dear mgkang,
    It appears you are running ocean from the UNIX command line> If so, you can interrupt an ocean script in a two ways based on my experience. I've included a third option if you submit your ocean script to a machine on your LSF compute farm.
    1. From the window in which you launched your command
    type a control-C.
    2. From a new window (the than the window in which you submitted your interactive ocean command), use the UNIX command ps -fu <userid> to list your jobs and find the job number of your ocean script. With the job number, for example job XXXX, type the UNIX command:
    kill -9 XXXX
    3. If youubmit your ocean script to a machine on your LSF compute farm, then you can terminate the job with number YYYY with the LSF command:
    bkill YYYY
    Shawn
  • mgkang
    mgkang over 4 years ago in reply to ShawnLogan
    Dear, Shawn
    Thank you for your replying
    Unfortunately, your first suggestion doesn`t work
    I thought it may be risk to kill the process.
    If there`s nothing we can do, I will do that
    mgkang
