  3. netlist creation issue
  • Views 11594
sjwprcker
sjwprcker over 4 years ago
I try two ways to create netlists of my testbench (IC618, maestro, spectre):
1. right click test name --> recreate the netlist --> the result is fine
2. right click the sim result --> view netlist --> i got different result vs case 1, some cells name with suffix "_schematic"
E.g., In case 1,
//Library name: XXX
//Cell name: XXX
//View name: schematic
//Inherited view list: XXX
subckt XXX...
ends XXX
In case 2,
//Library name: XXX
//Cell name: XXX
subckt XXX_schematic...
ends XXX_schematic
I have no clue how this happen, anyone knows this?
BR
    There are some valid cases where this happens, as explained in this article: Why does the spectre netlister add _schematic extension to subckt names.
    However, there were a number of cases where this was being added inconsistently and differently when re-netlisting was done. This was fixed (I believe) in IC6.1.8-64b.500.24 (and equivalent ICADVM20.1 version) as a result of CCR 2414230. So maybe that's the issue you're facing?
  • sjwprcker
    sjwprcker over 4 years ago in reply to Andrew Beckett
    Thanks a lot to provide such a helpful case. I fully understand the reason.
    I have a following up question is, is there any way, e.g., env_variable to force re-netlist but not incremental netlist in assembler?
    BR
    Andrew Beckett over 4 years ago in reply to sjwprcker
    There is a variable that can be used to force re-netlisting, but it's generally a bad idea to set this as then people set it and forget, and then complain about netlist performance. So I don't particularly want to advertise or promote it here as it's very much a workaround.
    Can you move to a more recent hotfix to see if that solves the problem?
