  3. Cadence Vrituoso
  • Subscribers 136
  • Views 13787
Cadence Vrituoso
younghyun
younghyun over 4 years ago
I was making an inverter out of  Verilog-A a using the Cadence Vertuoso tool (IC618)
but an error occured.
------------------------------------------log------------------------------------------
(TE-7051): Saved changes to /home/isdl/sangmyung/inv/veriloga/veriloga.va
(TE-4223): Extracting cellview 'sangmyung inv veriloga' ...
WARNING : There is some issue in invoking spectre command for parsing the text file /home/isdl/sangmyung/inv/veriloga/veriloga.va .
Make sure that the setting is proper
*WARNING* (TE-1308): Failed to perform syntax check for cellview 'sangmyung inv veriloga'.
*WARNING* (TE-1312): Compilation errors or warnings have been detected in the HDL file for cellview 'sangmyung inv veriloga'. To view the parse log for details, choose 'Parser Log File' from the 'View' menu.
*WARNING* (TE-4309): Extract failed for cellview 'sangmyung inv veriloga'
I wrote the code in verilog-A like this:
`include "constants.vams"
`include "disciplines.vams"
module inv(in, out);
input in;
output out;
electrical in, out;
parameter real threshold = 0.5;
real result;
analog begin
result = ((V(in) > threshold) ? 0 : 1);
V(out) <+ result;
end
endmodule
I think there is no problem wih the code.
and if I press the "Build a database of instances, nets and pins found in file" button, and extract failed error occurs.
How do i solve this problem
plz help me
    Do you have spectre in your UNIX path? (i.e. if you type "spectre -W" at the UNIX terminal, what does it return?). Did the Parser Log file show anything? Andrew
  • younghyun
    younghyun over 4 years ago in reply to Andrew Beckett +1
    first thank for the reply OS: CENTOS 7 version: IC6.1.8-64b.500.12 1. If I type "spectre -W", 'bash: spectre: not found command' is return - I don't no how to set the spectre 2. parser log file…
    Andrew Beckett over 4 years ago in reply to younghyun +1
    You need to ensure that your UNIX path (in the $PATH variable since you're using bash, it seems) contains the <SPECTREinstDir>/bin directory. You must have the IC release in your path already to run virtuoso…
  • younghyun
    OS: CENTOS 7
    2. parser log file is same as above log
    You need to ensure that your UNIX path (in the $PATH variable since you're using bash, it seems) contains the <SPECTREinstDir>/bin directory. You must have the IC release in your path already to run virtuoso - so check your $PATH env var and you'll need to add the spectre release (e.g. SPECTRE211) to that path. Otherwise you're not going to be able to simulate with spectre either.
  • younghyun
    Thank you Andrew !!!!!!!!!!!!!!!!!
    I solved the problem. :)
  • pengchaoqun
    pengchaoqun over 4 years ago in reply to younghyun
    I woder how you slove it,may you share?
  • pengchaoqun
    pengchaoqun over 4 years ago in reply to Andrew Beckett
    hello,I also met this problem,but when I type in echo $PATH, it shows echo $PATH
    /home/eda/mentor/Calibre2017.1/aoi_cal_2017.1_34.33/bin:/home/eda/cadence/XCELIUM1803/bin:/home/eda/cadence/XCELIUM1803/tools/bin:/home/eda/cadence/INNOVUS181/bin:/home/eda/cadence/GENUS171/tools/bin:/home/eda/cadence/SPECTRE181/bin:/home/eda/cadence/SPECTRE181/tools/relxpert/bin
    the problem “(TE-4309) extract failed for cellview....” still existing
