  3. Using "libName" as a function argument
  • Subscribers 136
  • Views 2726
MorrisDH
MorrisDH over 4 years ago
No issue. Just commenting on an observation.
Developing a script that parses cells in a library and one of the functions in the script takes the library name as an argument.
I was using "procedure( funcName(libName)..." and the script was getting numerous DB-270211 warnings and sometimes returning errors on dbSave. Debugged with print statements and stepping through the code but nothing made any sense. Then tried "procedure( funcName(Library)..." and all warnings and errors evaporated.
So I guess using "libName" as a variable is a no-no.
    Andrew Beckett over 4 years ago in reply to drdanmc +1
    Dan's suggestion is highly likely to be the reason here. SKILL has dynamic scoping (SKILL++ uses lexical scoping and won't have this problem) - so that means that each variable ends up as a stack - each…
  • MorrisDH
    Meant to put the comment in the "SKILL" forum. Sorry.
  • drdanmc
    drdanmc over 4 years ago in reply to MorrisDH
    There should be no issue with "libName" as a function argument.  I do that all the time.   What I immediately suspect is perhaps your code is calling some function that uses libName internally but forgot to add it to a let() to make it local.  I'm attach a concrete example demonstrating a really easy bug to introduce regarding variable scoping in SKILL.  To make things worse, mySubFnBad() might be in a compiled function from a foundry that gets called as part of a library libInit.il.  So you don't even know that someone else's buggy code is stomping on your variable.  I've for sure run into that before.
    ;; this code is not so useful but it is at least not broken.  libName is correctly listed in the let() and so it has local scope
    procedure(mySubFnGood(txt)
        let( (libName)
            libName = strcat(txt "_mysfx_good")
           ;; return the modified string
            libName
    ;; this broken code does *not* correctly list libName in the let() and so the assignment will overwrite the value of
    ;; libName in the calling function which can cause frustrating and hard to track down bugs.  Catching this is one of the
    ;; *huge* benefits of running sklint() because this is a really really easy bug to introduce and it can lurk for years before
    ;; causing problems.
    procedure(mySubFnBad(txt)
        let( (libname) ;; misspelled libName here on purpose, but we could just as easily have forgotten to include libName in the list
            libName = strcat(txt "_mysfx_bad")
            libName
    ;; nothing in this code intentionally modifies the libName argument
    procedure(myTopFn(libName)
       let( (r)
            printf("called %s(%L)\n" getCallingFunction(0) libName)
            r = mySubFnGood(libName)
            printf("mySubFnGood() returned %L and now libName = %L\n" r libName)
            r = mySubFnBad(libName)
            printf("mySubFnBad() returned %L and now libName = %L\n" r libName)
    myTopFn("myLib")
  • MorrisDH
    MorrisDH over 4 years ago in reply to drdanmc
    The variable got passed to the function as an argument. I could be wrong but I don't think an argument can be localized.
  • drdanmc
    correct, but does your function call any other functions?  If so, look in those other functions to see if any used `libName` as an internal variable and forgot to localize it.
    Dan's suggestion is highly likely to be the reason here. SKILL has dynamic scoping (SKILL++ uses lexical scoping and won't have this problem) - so that means that each variable ends up as a stack - each time you enter a new scope (e.g. a variable defined in a let, or as an argument to a function - note that function arguments are local to the function itself), then any variable access during the run time of the function or its descendants will see whatever is top of the stack. I cover this a little in my Writing Good SKILL Code video (search on support.cadence.com for this). So any function you call which fails to declare a variable as local can capture a variable with the same name in any parent function (this is the nature of dynamic scoping).
