  3. synthesizing Verilog code in Cadence Virtuoso
  • Views 12745
Senan
Senan over 4 years ago
I would like to ask you how I can synthesize a logic gate from my Verilog RTL description. For example, I have made a simple 4-bit counter in Verilog and I have tested the functionality with the AMS simulation, it is working fine but now I want to translate this code to logic gate in Cadence Virtuoso and do the layout of it.
I am using Cadence Virtuoso version 6.1.8-64b
Thank you in advance
Regards
  • Saloni Chhabra
    Saloni Chhabra over 4 years ago +1
    Hi, RTL to gate-level netlist conversion is done using our synthesis tool called Genus. You can't do this in Virtuoso. Regards, Saloni
  • Saloni Chhabra
    Saloni
  • Senan
    Senan over 4 years ago in reply to Saloni Chhabra
    Dear Saloni
    Thank you very much for your answer
    Regards
