  3. datapoints/memory array
  • Views 4312
Omar Ghazal
Omar Ghazal over 4 years ago
HI everyone
I have two questions here
first: how to convert a set of datapoints (stored in a text file) each having ten bits (b0.....b9) to be the input trigger of ten pulses sources (V0..V9) with timing between reading each datapoint 30 ns..See the photo plz
Second : I am working on designing a memory array if I have one cell (1bit ) designed and now I want to verify that it can be work as an array of 1Mbit (1024 bits) So how can I multiply the design in an array of 1024 because its hard to make all these connection . Any ideas.
    ShawnLogan over 4 years ago +1
    Dear Omar Ghazal, Omar Ghazal said: how to convert a set of datapoints (stored in a text file) each having ten bits (b0.....b9) to be the input trigger of ten pulses sources (V0..V9) with timing between…
    Dear Omar Ghazal,
    If I understand your question, you would like to create a subcircuit that can read a 10 bit bus contained in a test file and apply each bit as the input to 10 pulse generators. If so, I put together an example of a subcircuit implemented in veriloga. I placed a note with the test bench I assembled at URL:
    https://www.dropbox.com/s/7jix0i0d1efmgdz/omar_10bit_bus_example_sml_081722v1p0.pdf?dl=0
    The note also includes the veriloga source code, test bench variables, outputs, and example waveforms. Your input data file does not contain any delimiters - which with my limited skills in veriloga, makes the coding difficult as veriloga does not have a lot of functions to parse a string by character by character without a delimiter. Hence, I wrote a UNIX script to do the conversion to a "csv" file and have included that script. It takes as its input your text file with no delimiters between bits and creates a ".csv" version with a comma delimiter between bits. This file is placed in your working directory and modify the veriloga code to use the full path to this file in lieu of the path I used for the file.
    The veriloga and UNIX script are attached if they are useful to you.
    To be honest, you have not provided me, anyway, enough information with regard to the specific memory topology you are trying to create and what inputs to the cells are common to provide any helpful ideas, Sorry.
    Shawn
    Dear Omar Ghazal,
    The veriloga and UNIX script are attached if they are useful to you. I had to change to file extensions to ".txt" to upload them.
    Shawn
    Fullscreen 5430.convert_to_csv.txt Download
    #!/bin/ksh
    if [ $# -ne 1 ]; then
        echo "Usage: convert_to_csv < filename> "
        exit 127
    fi
    cp -p $1 tempfile0
    sed '1,$s/00/0,0/g' tempfile0 > tempfile1
    sed '1,$s/11/1,1/g' tempfile1 > tempfile0
    sed '1,$s/01/0,1/g' tempfile0 > tempfile1
    sed '1,$s/10/1,0/g' tempfile1 > tempfile0
    mv tempfile0 $1.csv
    rm tempfile1
    echo "Completed! Output file is \"$1.csv\"."
    Fullscreen 5430.veriloga.txt Download
    // VerilogA for sdd5e_TB, ten_bit_word_gen_triggered, veriloga
    // Crude code to provide example of subcircuit to read 10 bit bus from file
    // and provide subsequent 10-bit output on rising edge of input clkin
    // Missing many features and insufficient file checking...but works..
    // sml 8/17/2022 v1.0
    `include "constants.vams"
    `include "disciplines.vams"
    module ten_bit_word_gen_triggered(v0,v1,v2,v3,v4,v5,v6,v7,v8,v9,clkin);
    input clkin;
    output v0,v1,v2,v3,v4,v5,v6,v7,v8,v9;
    electrical v0,v1,v2,v3,v4,v5,v6,v7,v8,v9,clkin;
    integer file;
    integer count, count0,count1,count2,count3,count4,count5,count6,count7,count8,count9;
    integer input_string;
    real tdelay, trise, tfall, vthreshold;
    real val0, val1, val2, val3, val4, val5, val6, val7,val8,val9;
    real v0_int,v1_int,v2_int,v3_int,v4_int,v5_int,v6_int,v7_int,v8_int,v9_int;
    analog begin
         @(initial_step) begin
             count0 = 0;
             count1 = 0;
             count2 = 0;
             count3 = 0;
             count4 = 0;
             count5 = 0;
             count6 = 0;
             count7 = 0;
             count8 = 0;
             count9 = 0;
             tdelay = 0;
             trise = 100e-12;
             tfall = 100e-12;
             vthreshold = 0.50;
            file = $fopen("/project/sdd5e/users/smlogan/cds/omar_10bit_bus_example.txt.csv", "r");
            if ( $fscanf(file, "%f,%f,%f,%f,%f,%f,%f,%f,%f,%f",val0,val1,val2,val3,val4,val5,val6,val7,val8,val9 ) == 10 ) begin
               count0 = val0;
               count1 = val1;
               count2 = val2;
               count3 = val3;
               count4 = val4;
               count5 = val5;
               count6 = val6;
               count7 = val7;
               count8 = val8;
               count9 = val9;
             end
                v0_int = val0;
                v1_int = val1;
                v2_int = val2;
                v3_int = val3;
                v4_int = val4;
                v5_int = val5;
                v6_int = val6;
                v7_int = val7;
                v8_int = val8;
                v9_int = val9;
       end
    @ cross(V(clkin)-vthreshold, +1) begin
            count0 = 0;
            count1 = 0;
            count2 = 0;
            count3 = 0;
            count4 = 0;
            count5 = 0;
            count6 = 0;
            count7 = 0;
            count8 = 0;
            count9 = 0;
            trise = 100e-12;
            tfall = 100e-12;
            vthreshold = 0.50;
            count0 = val0;
            count1 = val1;
            count2 = val2;
            count3 = val3;
            count4 = val4;
            count5 = val5;
            count6 = val6;
            count7 = val7;
            count8 = val8;
            count9 = val9;
          end
             v0_int = val0;
             v1_int = val1;
             v2_int = val2;
             v3_int = val3;
             v4_int = val4;
             v5_int = val5;
             v6_int = val6;
             v7_int = val7;
             v8_int = val8;
             v9_int = val9;
    end
       V(v0) <+transition(v0_int, tdelay, trise, tfall);
       V(v1) <+transition(v1_int, tdelay, trise, tfall);
       V(v2) <+transition(v2_int, tdelay, trise, tfall);
       V(v3) <+transition(v3_int, tdelay, trise, tfall);
       V(v4) <+transition(v4_int, tdelay, trise, tfall);
       V(v5) <+transition(v5_int, tdelay, trise, tfall);
       V(v6) <+transition(v6_int, tdelay, trise, tfall);
       V(v7) <+transition(v7_int, tdelay, trise, tfall);
       V(v8) <+transition(v8_int, tdelay, trise, tfall);
       V(v9) <+transition(v9_int, tdelay, trise, tfall);
    $fclose( file );
    end
    endmodule
  • Omar Ghazal
    Omar Ghazal over 4 years ago in reply to ShawnLogan
    Thanks  that's really helpful
    ShawnLogan over 4 years ago in reply to Omar Ghazal
    Dear Omar,
    Wonderful - that is all that matters! My pleasure and good luck! Thank you for letting us know!
    Shawn
