  3. how to plot dynamic parameter "temp"
  • Views 5571
sjwprcker
sjwprcker over 4 years ago
I have defined a dynamic parameter "temp" in a tran simulation.
I wish to  make an expression in the output setup. However, temp seems only available in the data browser as a variable, which is only one default value.
Is there any way to plot dynamic parameter "temp"?
BR
    ShawnLogan over 4 years ago
    Dear sjwprcker,
    temp is a reserved term in Spectre and should not be used as a design variable. This is outlined in the Troubleshooting article
    https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1O3w000009xxe7EAA&pageName=ArticleContent&oMenu=People%20who%20viewed%20this%20also%20viewed
    under the Q&A item "Can I use temp as a design variable name in ADE?"
    This same article also answers your previous question concerning the different between "nom" and "temp" when used as a dynamic parameter,
    As to how to plot the temperature as a function of time in a transient simulation where temperature is a dynamic parameter, you might find the note at URL:
    https://www.dropbox.com/s/wmg6pg65th09clg/saving_temp_vs_time_example_081822v1p0.pdf?dl=0
    helpful. This describes a couple of ways  to include the simulation temperature as an output. Once it is defined as an output, one can plot it using ViVA. An example is provided that I hope will clarify the process. I originally provided this in response to the Forum post on 8/17/2022 at:
    https://community.cadence.com/cadence_technology_forums/f/custom-ic-design/52303/how-to-plot-temperature-vs-time-in-viva
    Shawn
  • sjwprcker
    sjwprcker over 4 years ago in reply to ShawnLogan
    Perfect answer, thanks a lot!
    ShawnLogan over 4 years ago in reply to sjwprcker
    Dear sjwprcker,
    Great! I am just happy to read that at least I understood your question correctly! Thanks for letting us know!
    Shawn
