  3. spectreVerilog Simulation Stable DC solution not found ...
  • Views 10199
spectreVerilog Simulation Stable DC solution not found error
Celuk
Celuk over 4 years ago
Hi all,
I want to simulate a multiplier design with verilog testbench but I am facing with this error:
ERROR (ADE-3076): Errors encountered while executing verilog. Unable to read Status file.
Verilog/spectre Mixed-Signal Interface 2.0
Message! Stable DC solution not found within 0
iterations. Using last calculated state to start
transient analysis. See Artist Mixed-Signal
Simulation Help for more info on obtaining an
initial solution. [Mixed_Sig]
"IE.verimix", 5: $vmx_initialize("spectre",
dc_mode_flag);
Error! List of message(s) that are acceptable now:
$do_dc
$done_dc
$switch_to_interactive
Invalid message introducer '$send_events',
unrecognized. [Mixed_Sig-VMXIMI]
"IE.verimix", 5: ...
Error! Invalid message introducer '0', expect DONE_DC
message. [Mixed_Sig-VMXIMI]
dc_mode_flag);
Verilog/spectre Interface: 42 messages sent, 43 messages received.
2 errors
I searched a little bit and find this old similar questions:
https://comp.cad.cadence.narkive.com/NFBFqSZO/problem-encountered-during-simulating-with-spectreverilog
Tried ams instead of spectreVerilog and it didn't resolve.
https://community.cadence.com/cadence_technology_forums/f/custom-ic-design/37352/dc-convergence-problem
Tried to ramp up VDD to 10 Volt instead of 5 Volt and the simulation done without errors but Verilog display output for circuit's outputs is 0. (This cannot because of the circuit right? Even if I am mistaken in the schematic, it cannot be all zero for several inputs. I also tried different parameters in Verimix.)
So it seems there is no problem for analog simulations but I failed at verilog simulations and any help will be appreciated.
Seyyid
Verilog testbench schematic (with spectreVerilog config):
Verilog testbench code (I didn't use multiple bit declarations because I also suffered from bus'es in the testbench schematic):
//Verilog HDL for "proje", "multiplier_8x8_tb_vdriver" "functional"
`timescale 10us/1us
module multiplier_8x8_tb_vdriver ( c, p15, p14, p13, p12, p11, p10, p9, p8, p7, p6, p5, p4, p3, p2, p1, p0, x7, x6, x5, x4, x3, x2, x1, x0, y7, y6, y5, y4, y3, y2, y1, y0 );
input c, p15, p14, p13, p12, p11, p10, p9, p8, p7, p6, p5, p4, p3, p2, p1, p0;
output x7, x6, x5, x4, x3, x2, x1, x0, y7, y6, y5, y4, y3, y2, y1, y0;
reg x7, x6, x5, x4, x3, x2, x1, x0, y7, y6, y5, y4, y3, y2, y1, y0;
initial begin
x7=1'b0; x6=1'b0; x5=1'b0; x4=1'b1; x3=1'b0; x2=1'b0; x1=1'b0; x0=1'b1;
y7=1'b0; y6=1'b0; y5=1'b0; y4=1'b1; y3=1'b0; y2=1'b0; y1=1'b0; y0=1'b1;
#1; $display("x:%d * y:%d --> %d", {x7, x6, x5, x4, x3, x2, x1, x0}, {y7, y6, y5, y4, y3, y2, y1, y0}, {c, p15, p14, p13, p12, p11, p10, p9, p8, p7, p6, p5, p4, p3, p2, p1, p0});
end
endmodule
    You must be using a rather old and unsupported version of the tools, since spectreVerilog was removed in IC617 (almost 7 years ago) and even before that it was obsolete for many years. I don't know what "Tried ams instead of spectreVerilog and it didn't resolve" means, but using AMS as the simulator is the way forward.
    There's not enough detail to understand what your problem is here - perhaps you could contact customer support?
