  3. Virtuoso command not found
  • Replies 21
  • Subscribers 137
  • Views 34824
VoTuanMinh
VoTuanMinh over 4 years ago
Dear,
I am sorry if this error is already asked somewhere.
I have installed the Spectre211 and IC618 using the InstallScape on Centos 7.9 (shown in the figure).
However, when I try to run virtuoso command, the error of "virtuoso command not found" appears.
Could anyone please help me with this error?
I am not so familiar with the Linux OS, so please forgive me for such simple question.
Thank you.
Minh
    Have you set your $path (if using csh) or $PATH environment variable (if using bash/ksh) to include <ICinstDir>/tools/bin and <ICinstDir>/tools/dfII/bin ? If not, you won't be able to find the software…
    Have you set your $path (if using csh) or $PATH environment variable (if using bash/ksh) to include <ICinstDir>/tools/bin and <ICinstDir>/tools/dfII/bin ? If not, you won't be able to find the software since this is the mechanism that Linux (and UNIX flavours for ever) use to find commands with a relative path.
  • AtaV
    AtaV over 4 years ago in reply to Andrew Beckett
    I am having the same problem. I have all of the environment variables defined as shown below and I am able to see it when I type "which virtuoso" and "which spectre". However, when I type "virtuoso" it shows command not found. I would appreciate it if you could help me with this.
    Andrew Beckett over 4 years ago in reply to AtaV
    Running as root is not a good idea, but perhaps your issue is that "ksh" might be missing? Is /bin/ksh present on your machine? If not, you'll need to install the "ksh" package (rpm).
  • AtaV
    Thanks a lot for your reply. You were right and ksh was not installed on the system. I installed it and it resolved that issue. However, now I a facing another problem as shown below. Both virtuoso and virtuoso -W commands ended up with the same problem.
    You'll need to ensure that the openssl-devel RPM is installed. You should check by using:
    $CDSHOME/tools/bin/checkSysConf ICADVM20.1
    where $CDSHOME is wherever your installation is (i.e. /softwares/Cadence/ICADVM201 in your case).
  • AtaV
    Thanks a lot, Andrew. It worked and all the requirements are passed. However, while starting the cadence I face a black screen as seen below and after a while, it is gone and nothing happens.
    What do you mean by "it is gone and nothing happens"? Do you mean that virtuoso has exited? If so, it may be your licensing is not set up - is $CDS_LIC_FILE set to point to your license server? (e.g. 5280@hostname) and do you have the licenses running? Does "lmstat -a -c $CDS_LIC_FILE" show that the licenses are available?
  • AtaV
    Yes, I meant the virtuoso was exited. Yes, I have the license setup as you mentioned. But I am not sure if it automatically starts or if I have to start it manually.
    Without knowing how you've set up the licenses, it's really hard to know. Did the "lmstat" output show the licenses as available and running?
    You really should do this via customer support. Debugging this via the forums is not terribly efficient...
  • VoTuanMinh
    VoTuanMinh over 4 years ago in reply to Andrew Beckett
    Dear Andrew,
    I am so sorry for the late reply.
    We have tried as your instruction, however, we got the same error as above related the shared library.
    Could you please help us with this error.
    best regards,
    Minh
