  3. Virtuoso command not found
  • Replies 21
  • Subscribers 137
  • Views 34825
VoTuanMinh
VoTuanMinh over 4 years ago
Dear,
I am sorry if this error is already asked somewhere.
I have installed the Spectre211 and IC618 using the InstallScape on Centos 7.9 (shown in the figure).
However, when I try to run virtuoso command, the error of "virtuoso command not found" appears.
Could anyone please help me with this error?
I am not so familiar with the Linux OS, so please forgive me for such simple question.
Thank you.
Minh
    Have you set your $path (if using csh) or $PATH environment variable (if using bash/ksh) to include <ICinstDir>/tools/bin and <ICinstDir>/tools/dfII/bin ? If not, you won't be able to find the software…
  • AtaV
    AtaV over 4 years ago in reply to Andrew Beckett
    I have started the license server using the command below and I checked the status and it showed me the license server is running. Below is the screenshot of its log. Do you think there is a problem with it? I am not sure about FlexNet not being installed. From the photo attached do you think I am missing anything?
    "$lmgrd_Path"/lmgrd -c "$Cadence_License_Path"/Cadence_License_File.dat -l $Cadence_License_Path/daemon.log &
    Andrew Beckett over 4 years ago in reply to VoTuanMinh
    VoTuanMinh said:
    We have tried as your instruction, however, we got the same error
    The trouble is that your $PATH is set incorrectly. You should not include <instDir>/tools/dfII/bin/64bit in the path. That will bypass the wrapper script that adds the search path for all the shared libraries. You should include <instDir>/tools/dfII/bin and <instDir>/tools/bin and not the "64bit" extension. The wrappers take care of that for you.
    Andrew Beckett over 4 years ago in reply to AtaV
    If that's the complete log file, then something is wrong because it doesn't list any license features. I would strongly suggest you contact customer support because it's really hard to diagnose a problem based on a screenshot of part of a log file!
    Andrew Beckett said:
    You really should do this via customer support. Debugging this via the forums is not terribly efficient...
    This could then have been solved 12 days ago...
  • CadK1
    CadK1 over 4 years ago in reply to Andrew Beckett
    I am having the same issue here my script for setting path etc. is
    setenv CDSHOME /eda/cadence/2021-22/RHELx86/IC_6.1.8.210
    setenv CDS_LIC_FILE 5280@mylicenceserver
    set path = ($CDSHOME/tools/dfII/bin $CDSHOME/tools/dfII/bin $path )
    which virtuoso
    virtuoso
    how should I set the path the solve this issue ?
    Andrew Beckett over 4 years ago in reply to CadK1
    Assuming that if you do:
    ls -l $CDSHOME/tools/lib/64bit/libap_sh.so
    the file exists (it should in the version you're using), then the only thing I can think of is that maybe you're running on some unsupported OS. What do you get from:
    /bin/lsb_release -a
    Can you also try running:
    $CDSHOME/bin/checkSysConf IC6.1.8
  • CadK1
    this is the OS
    and it didn't find the command.
    libap_sh.so exists
  • CadK1
    CadK1 over 4 years ago in reply to CadK1
    $CDSHOME/tools/bin/checkSysConf IC6.1.8
    (the path was different in an older version that you're using). Please also don't post screenshots of the output as (a) they're not complete and (b) they aren't searchable or copy-pastable.
  • CadK1
    ok CheckSysconf passes everything
  • CadK1
    I solved the problem by reinstalling everything. Now Virtuoso is starting very slowly and there is the following message : *Error* Could not connect with cdsMsgServer for session virtuoso11729 on host
