  3. Virtuoso command not found
  • Replies 21
  • Subscribers 137
  • Views 34836
VoTuanMinh
VoTuanMinh over 4 years ago
Dear,
I am sorry if this error is already asked somewhere.
I have installed the Spectre211 and IC618 using the InstallScape on Centos 7.9 (shown in the figure).
However, when I try to run virtuoso command, the error of "virtuoso command not found" appears.
Could anyone please help me with this error?
I am not so familiar with the Linux OS, so please forgive me for such simple question.
Thank you.
Minh
    Have you set your $path (if using csh) or $PATH environment variable (if using bash/ksh) to include <ICinstDir>/tools/bin and <ICinstDir>/tools/dfII/bin ? If not, you won't be able to find the software…
    Andrew Beckett over 4 years ago in reply to CadK1
    There's this: Virtuoso ISR20 is slow to start; 'Could not connect with cdsMsgServer' and spawning multiple perl jobs (saveLogs.pl) but since you appear to be using the fixed version, it's probably not that. I'd suggest contacting customer support. (this is already a different issue from the original post and the forum guidelines ask you not to post on the end of older threads).
