  3. Shortcut to Open Layout View of Currently Open Cell in New...
  • Views 14573
Shortcut to Open Layout View of Currently Open Cell in New Tab
sgcad
sgcad over 4 years ago
Hi
I'd like to add a shortcut (say F12) to Virtuoso such that when I have an arbitrary view (in particular schematic or symbol) open, the corresponding layout view opens in a new tab. As I'm new to skill, I only managed to get to the point where F12 opens a specific cell view in a new tab from a schematic:
hiSetBindKey("Schematics" "<Key>F12" "geOpen(?window hiGetCurrentWindow()~>sessionWindow ?lib \"basic\" ?cell \"GND\" ?view \"symbol\" ?viewType \"schematicSymbol\" ?mode \"r\")")
Could you help me with the following next steps:
  • How can I modify the command such that the shortcut also works from views other than schematic? Do I have to repeat the hiSetBindKey command for every view type that I'd like to support, or is there a more elegant way?
  • How can I modify the command such that it opens a specific view (in particular: layout) of the current cell?
Thanks very much!
    Andrew Beckett over 4 years ago in reply to RicardoGV1 +1
    RicardoGV1 said: Adding to what Andrew said, you could use deGetAllRootTypes ( ) to get all View-types an iterate over that. Although most of those applications wouldn't make sense given that geGetEditCellView…
  • RicardoGV1
    RicardoGV1 over 4 years ago
    Hi Sgcad,
    There was a post about changing between schematic and layout views, so maybe this will help you as an starting point.
    /**********CHANGE BETWEEN SCHEMATIC AND LAYOUT (bindkeys on bottom)*********/
    ;also asks to create the cell in case don't exists.
    procedure(myOpenOtherView(@optional (viewName nil) (cv geGetEditCellView()))
      let((cellWin otherCv msg dbox viewType)
        unless(stringp(viewName)
            if(cv~>viewName=="schematic" then
                viewName="layout"
                viewType="maskLayout"
            else
                viewName="schematic"
                viewType="schematic"
        otherCv = dbOpenCellViewByType(cv~>libName cv~>cellName viewName)
        if(otherCv then
            unless(geGetCellViewWindow(otherCv)
                deOpenCellView(otherCv~>libName otherCv~>cellName otherCv~>viewName viewType nil "r")
            ) ;unless
            cellWin=geGetCellViewWindow(otherCv)
            hiDeiconifyWindow(cellWin)
            hiSetCurrentWindow(cellWin)
            hiRaiseWindow(cellWin)
        else
            hiGetAttention()
            sprintf(msg "**WARNING: Could not open %s %s %L\n" cv~>libName cv~>cellName viewName)
            sprintf(msg "%s           Would you like to create this view?\n" msg)
            dbox=hiDisplayAppDBox(?name 'dBox ?buttonLayout 'YesNo ?dboxText msg ?dboxBanner "Create this view?")
            if(dbox then
                printf("Creating: %s %s %L\n" cv~>libName cv~>cellName viewName)
                if(otherCv = dbOpenCellViewByType(cv~>libName cv~>cellName viewName viewType "a") then
                    deOpenCellView(otherCv~>libName otherCv~>cellName otherCv~>viewName viewType nil "a")
                else
                    hiGetAttention()
                    printf("**ERROR: Could not create %s %s %L\n" cv~>libName cv~>cellName viewName)
            else
                printf("Cell view %s %s %L does not exist and was not created\n" cv~>libName cv~>cellName viewName)
        otherCv
      ) ;let
    ) ;proc
    hiSetBindKey("Layout" "Shift<Key>w" "myOpenOtherView()")
    hiSetBindKey("Schematics" "Shift<Key>w" "myOpenOtherView()")
    Also, if this wasn't what you were looking for, please, add your Cadence Version with: getVersion() and getVersion("virtuoso")
    This in case somebody needs it.
    R. Gómez
  • sgcad
    sgcad over 4 years ago in reply to RicardoGV1
    Thanks, that helped. For completeness, the post you mentioned is here: How to open a schematic window from a layout window and the resulting code (for Virtuoso 6.1.8) as follows:
    hiSetBindKey("Schematics" "<key>F12"
      "geOpen(
        ?lib geGetEditCellView()~>libName
        ?cell geGetEditCellView()~>cellName
        ?view \"symbol\"
        ?mode \"r\"
    I still wonder if there's a simple way to replace the first line with something that allows this shortcut to work also from other views, instead of repeating the hiSetBindKey many times for every view type I'd like to support?
    Andrew Beckett over 4 years ago in reply to sgcad
    You could add a simple loop around this to define it for more than one application:
    foreach(application '("Schematics" "Symbol" "Layout")
      hiSetBindKey(application "<key>F12"
        "geOpen(
          ?view \"symbol\"
          ?mode \"r\"
  • RicardoGV1
    RicardoGV1 over 4 years ago in reply to sgcad
    Adding to what Andrew said, you could use deGetAllRootTypes() to get all View-types an iterate over that.
    Also there is a post Method for raising a specific design window from a list in which they list and raise opened windows. This as another workaround where you can choose which one to open.
    R.Gómez
    Although most of those applications wouldn't make sense given that geGetEditCellView() wouldn't work on them all. So buyer beware...
  • sgcad
    sgcad over 4 years ago in reply to Andrew Beckett
    Works perfectly, thanks! Thumbsup
