  3. What are the noise options under simulator options?
  • Views 11168
david73
david73 over 4 years ago
IN ADE_XL, using spectre, under simulator options, there is an options to turn on/off different types of noise contributions for different instances
Can someone give some explanation as to how to use these options? does it remove these noise components from the simulation or only from the analysis after the simulation?
Where can I find more information about this?
    ShawnLogan over 4 years ago +1
    Dear david73, david73 said: Where can I find more information about this? A document detailing the definitions of the noise types is at the Cadence On-line support site at URL: https://support.cadence…
    Dear david73,
    https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1Od0000000nazwEAA&pageName=ArticleContent&oMenu=People%20who%20viewed%20this%20also%20viewed
    with a description of the use of the noiseon and noiseoff options at URL:
    https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1Od0000000vK9ZEAU&pageName=ArticleContent
    I noticed in your post you indicated "ADE_XL". The documentation URL is pertinent to ADE Assembler/Explorer. Hopefully, it provides enough background fr your use. If you have not considered it, I might suggest you consider migrating from ADEXL to Assembler/Explorer. The transition is quite easy and the latter simulators are both supported and full featured.
    Shawn
