  3. Spectre noise type definitions
  • Replies 7
  • Views 15724
livingstone
livingstone over 4 years ago
Are there documented definitions for the noise types in Simulation -> Options -> Analog and how the model parameters are overridden/modified when turned on/off? I am specifically interested in what "ign" is referring to - induced gate noise? When I run a simulation checking or unchecking the "flicker" option seems to have no effect while checking/unchecking "ign" seems to remove the flicker component. The PDK provider did inform me that noise has not been modeled so I'm assuming some sort of default is being invoked.
Virtuoso version: IC6.1.8-64b.500.23
Spectre version: 21.1.0.208.isr3
    ShawnLogan over 4 years ago +2
    Dear livingstone, livingstone said: Are there documented definitions for the noise types in Simulation -> Options -> Analog and how the model parameters are overridden/modified when turned on/off? …
    ShawnLogan over 4 years ago in reply to livingstone +1
    Dear liivingstone, Thank you for letting me it was somewhat useful! I can understand your confusion! I've put together an example where I've tried to show the noise results with and without flicker…
    ShawnLogan over 4 years ago in reply to ShawnLogan +1
    Dear livingstone, A bit late, but Ive put together an example of four noise simulations with various combinations of the noise on/off settings in the analog options noise GUI. There is a priority as…
    Dear livingstone,
    There are a couple of documents in the response to the recent Forum post at URL:
    https://community.cadence.com/cadence_technology_forums/f/custom-ic-design/52441/what-are-the-noise-options-under-simulator-options/1385408#1385408
    In addition, with respect to your comment regarding checking or unchecking the flicker option and your simulation result, the note regarding "Confusing results when using noiseon_type and noiseoff_type..." at URL:
    support.cadence.com/.../ArticleAttachmentPortal
    may be of interest.
    Yes. "ign" is an acronym for "induced gate noise". In spite of its name, my understanding is its origin is in the thermal noise within the channel.
    I hope these help livingstone!
    Shawn
    • Vote Up +2 Vote Down
  • livingstone
    livingstone over 4 years ago in reply to ShawnLogan
    Hi Shawn,
    Yes that was helpful, thank you.
    I am not 100% clear on how the 'noiseon_type' and 'noiseoff_type' selections work in my case (despite reading the troubleshooting post you shared), but after playing with it some more I realized that 'noiseoff_type' isn't doing much of anything whereas 'noiseon_type' is.
    The logic seems to be something like: if nothing is checked in 'noiseon_type' then everything is on whereas if one or more are checked then the remaining are disabled, and again 'noiseoff_type' doesn't seem to do anything. Previously I had checked 'thermal' in 'noiseon_type' and 'ign' in 'noiseoff_type' and wrongly concluded that 'ign' was behaving like 'flicker'.
    Dear liivingstone,
    I can understand your confusion! I've put together an example where I've tried to show the noise results with and without flicker noise included. There are a couple of radio button settings that will accomplish the latter,  and I've documented each. Give me a little time and I'll send the example later today if you still have the time and patience!
    Shawn
    Dear livingstone,
    A bit late, but Ive put together an example of four noise simulations with various combinations of the noise on/off settings in the analog options noise GUI. There is a priority as is evident when you examine the netlist that results from the various noise GUI choices. As is also evident, the noiseoff_type settings do function when not "trumped" by the noiseon_type setting. See what you think. The short note is at URL:
    www.dropbox.com/.../ac_noise_on_off_functionality_091622v1p0.pdf
    Shawn
  • MohNaj
    MohNaj over 4 years ago in reply to ShawnLogan
    Hi ShawnLogan
    To my understanding, using on/off option for the instances divides them into two categories (on category and off category). Noiseon_type determines the noise sources for the on category and noiseoff_type determines the noise sources for the off category. To cover more combinations and have a better understanding of these options, you can create some cases where one of the inverters is in the off category.
    Mohammad
  • livingstone
    Hi Shawn,
    Thank you for looking into it and confirming that the behavior is the same. As Mohammad commented below the categories may make more sense when specifying individual instances. Still, I have to say that I find the GUI options somewhat confusing.
    Dear MohNaj and livingstone,
    Yes. This is what both livingstone and I pointed out. I believe the confusion arises when, for example, the noise_on "all" radio button is checked AND one of the noise_off noise source radio buttons is selected. The question is which option is applied. As I tried to show in the examples in the note at URL:
    the "noise_on" setting appears to "trump" the noise_off setting. As also shown in the note, the best way to check which noise source is on or off is to inspect the simulationOptions setting within the netlist created from a specific set of noise_on/noise_off radio button choices and realize the noise_on takes preference to noise_off.
    I agree with you as I mentioned in my initial response!
    Thank you for following up!
    Shawn
