  3. How to define a specific variable for each corner
  • Views 11447
sjwprcker
sjwprcker over 4 years ago
I would like to define a variable, X, which is based for each corner. E.g.,
FF, X = 1
FS, X = 2
SF, X = 3
SS, X= 4
etc.
One possible way is expand all corners in the setup and manually add such a variable. However, in case the number of corner is large, such a solution is not convenient.
I am wondering, if virtuoso can do this job in a simplified way?
BR
    ShawnLogan over 4 years ago
    Dear sjwprcker,
    If I understand your question correctly, I thought an example might help where a conditional expression is used to set a variable based on the corner selected. Hence, I assembled a few notes and placed them at URL:
    https://www.dropbox.com/s/hnjhlhl53hq568s/corner_dependent_variable_sml_092822v1p10pptx.pdf?dl=0
    There are a number of conditional expressions that may be used, and the "CASE" statement appears it might be best if you have a lot of cases..but will let you decide! I am just not sure of all the specifics of your simulation goal. The Cadence On-line support article at URL:
    https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1O3w00000AE15CEAT&pageName=ArticleContent
    provides a few examples of conditional expressions and their syntax. I hope this is helpful sjwprcker!
    Shawn
