  3. How to make use of the symbol_noconn for dangling verilog...
  • Views 9989
How to make use of the symbol_noconn for dangling verilog bus ports without shorting them ?
Emulator
Emulator over 4 years ago
I've a setup according to https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1Od0000000nZGd&pageName=ArticleContent , but for an intermediate Verilog netlist written out by Innovus, the generated fast schematic results in a bus being shorted in the schematic. The bus outputs of one instantiated module are not used in the instantiation - these are dangling.
The import is run with IC 6.1.8-500ISR13, verilog import with "fast" option ON (connection-by-name).
Is there any additional switch or option required to receive a schematic without shorted bus by the net <*4>netNoConn0  - as this shorts the bus data_o of the instantiated module master_test ?
The simple verilog netlist uses connection-by-name, there are some ports dangling (I removed the parts which are not relevant):
module master_test (in_i,test_o,data_i,data_o,test_o,test_chain_o,VDD,VSS);
output [3:0] data_o;
endmodule
module top_test (in_i,data_i,data_o,VDDM1,VSSM1);
master_test test_u (.in_i(in_i),.data_i(data_i),.VDD(VDDM1),.VSS(VSSM1));
endmodule
Any idea ?
Thanks a lot in advance.
    This looks like a bug to me - it shouldn't need a switch to do the right thing. Assuming it's not a bug that's been fixed in a later sub-version (we're now on .500.28), you should report this to customer support.
  • Emulator
    Emulator over 4 years ago in reply to Andrew Beckett
    Many thanks.
    Ok, I'll try a newer version - and in case - will contact our CAD team to talk to customer support.
    Greg
