  3. What is the phase relation between Spectre PSS one period...
  • Views 10168
What is the phase relation between Spectre PSS one period waveform and the corresponding PAC analysis
RFStuff
RFStuff over 4 years ago
Dear All,
We use PSS and PAC simulation. But I am still not sure what is the phase relation between Spectre PSS one period waveform and the corresponding PAC sideband's phase.
For example, Let's say PAC Sideband=0 atfrequency=0 has a phase of 40 degree.
Now this phase is referenced to what ? I assume it is related to one period waveform obtained through PSS-time plot .
Could anybody clarify on this. I have used Shooting method for PSS/PAC analysis.
Kind Regards,
    With PAC analysis, the phase is related to the phase of the source with PAC Magnitude set (there's the PAC Phase parameter on vsource/isource/port which allows you to set it to something other than 0).
  • RFStuff
    RFStuff over 4 years ago in reply to Andrew Beckett
    Dear Andrew,
    Thanks a lot for your reply.
    In PAC we find the sideband transfer functions Hm(jw). From these we can find the time-varying periodic transfer function H(jw,t) with period T. T=1/fs, i.e.the period of the LPTV system (the periodic clock that drives the LPTV system). wc=2*pi/T
    If I derive let's say H(0,t) from the pac sideband trnasferfunctions at f=0, Hm(0) (m here -50 to +50), how its phase will be with respect to the clock of the LPTV system (as both H(0,t) and the clock are periodic) ?
    Below, is the information taken from the publication  "Impulse Sensitivity Function Analysis of Periodic Circuits".
