  3. Whether virtuoso only loads the first .cdsinit file it ...
  • Views 11421
Whether virtuoso only loads the first .cdsinit file it finds
lightyear
lightyear over 4 years ago
I read the post   https://community.cadence.com/cadence_technology_forums/f/custom-ic-skill/37048/when-is-cdsinit-local-loaded
It tells me that the .cdsinit load order is:
  1. <ICinstDir>/tools/dfII/local/.cdsinit
  2. ./.cdsinit
  3. ~/.cdsinit
and
  " whichever file is found first in the search sequence is the only one loaded (by virtuoso). It does not load any later files in the sequence (unless that has been coded into the first .cdsinit file it loads)."
Is there a way to load later files ?
for example, our team put a public .cdsinit in <ICinstDir>/tools/dfII/local/.cdsinit,
everyone can load this file without any configurations
also allows users to have their own .cdsinit file in the work directory or $HOME
and while launch the virtuoso, it will load  <ICinstDir>/tools/dfII/local/.cdsinit  at first, then load .cdsinit in the work directory.
    The central .cdsinit (in tools/dfII/local/.cdsinit - or found via the setup.loc/Cadence Search File mechanism if that's been enabled) would have code something like:
    when(isFile("./.cdsinit") && isReadable("./.cdsinit")
      loadi("./.cdsinit")
    This could also look for similar files elsewhere (e.g. in your home directory), as you see fit.
  • lightyear
    lightyear over 4 years ago in reply to Andrew Beckett
    Thank you, Andrew, good idea, this does implement the method of loading cdsinit documents sequentially.
