  3. VCO phase noise modeling using a transient noise simula...
  • Replies 32
  • Subscribers 136
  • Views 36739
VCO phase noise modeling using a transient noise simulation
asrf
asrf over 3 years ago
Hi all,
I am trying to model VCO phase noise (for PLL) as shown in picture below:
I am using an integrator with gain of KVCO to integrate voltage noise to get excessive phase which is VCO phase noise.
I started with transient noise simulation of diode connected transistor voltage (Vn or Vnoise)
this is the results of noise simulation
however when I run transient noise simulation and use PSD calculator I dont get a proper result
integrator output is even worse Disappointed
    ShawnLogan over 3 years ago
    Dear asrf,
    Achieving reasonable correlation in phase noise between a transient noise simulation and pss/pnoise simulation is absolutely possible. However, it requires a significant amount of care in your choice of transient noise simulation settings, PSD analysis, and pss/pnoise simulator settings. The amount of information your Forum post provides does not include enough for me to give you concrete suggestions as your PSD GUI settings are not relevant without knowing the details of your transient noise and pss/pnoise analysis.
    However, I might suggest you study a similar question and the notes I assembled for each in the Forum posts at URL:
    https://community.cadence.com/cadence_technology_forums/f/rf-design/51484/comparing-transient-noise-pnoise-and-pnoise-with-lorentian-approximation-of-a-ring-oscillator
    There is a link to a set of notes that details considerations for comparing phase noise results for a transient noise simulation and pss/pnoise simulations.
    https://www.dropbox.com/s/5zalilay6sqa06b/phase_noise_response_081422v1p0.pdf?dl=0
    https://community.cadence.com/cadence_technology_forums/f/custom-ic-design/51696/snr-calculation-wrong-by-3-db/1383427?focus=true
    There is a link in this post to a set of notes describing some subtleties of using the Spectrum Assistant it produce PSD results from a transient noise simulation and a means to set your transient noise simulation parameters to produce valid Spectrum Assistant PSD results.
    Shawn
  • asrf
    asrf over 3 years ago in reply to ShawnLogan
    Thank you for your time and effort.
    These are my transient noise simulation setup
    Thank you for the links you have provided. I will study them.
    Some of these links are about phase noise. Here I am basically looking at voltage noise. (or integrated voltage noise)
    I am not running pss/pnoise since my circuit has verilogA code and it does not work.
    I use noise simulation to check Vnoise of diode connected transistor
    ShawnLogan over 3 years ago in reply to asrf
    Dear asrf,
    I thought your goal was to :
    and hence included the phase noise information. I understand your initial simulation efforts are aimed at correlating the small-signal AC noise results with those using the Spectral Assistant after a transient noise simulation. That is why I included the link to the second Forum post. Starting on page 15 of the dropbox link in the second Forum post,
    https://www.dropbox.com/s/7vxzliml4uz6518/psd_study_sml_090622v1p0.pdf?d|=0
    I compare the transient noise simulation results with the AC small signal noise results for 4550 ohm resistor with and without a bandlimiting 100 fF capacitor. I illustrate the impact of one's choice of noisefmax and sampling time on the integrated noise results. With the proper choice of noisefmax, sampling time, and integration step size, the small signal and transient noise/PSD results correlate quite well. From page 18 of the note, shown below as Figure 1, the data suggests the transient noise and AC small signal noise integrated values correlate well as long as the sample rate is chosen to be higher than the value of noisefmax.
    Looking at your transient noise simulation parameters, I note you have set noisefmax to 10 GHz. However, you have set the sample rate to 2.50 GHz. Hence, you will experience aliasing of noise components above 1.25 GHz into the lower frequency range and as also shown in Figure 1, the average PSD noise will be increased beyond its expected value.
    Inspecting the transient noise PSD noise results you show in your Forum post, the values appear much greater than those for your small signal noise results - which is consistent with the presence of aliasing.
    Further, inspecting your Spectral Assistant parameter "Peak Saturation level" in your initial Forum posts indicates you selected its value as 0. Hence, all measurements are expressed with respect to an rms level of 707 mV - not 1 V. If you are not familiar with the "Peak Saturation Level" parameter, you might want to review it using the Cadence help function or the manual. I outline its function in Figure 2 from a second note referenced in the Forum post:
    I hope this helps clarify my comments and included references asrf and is somewhat useful to you!
    Shawn
    Figure 1
    (from page 18 of https://www.dropbox.com/s/7vxzliml4uz6518/psd_study_sml_090622v1p0.pdf?d|=0   )
    Figure 2
    (from page 15 of link in Forum post: community.cadence.com/.../1383427
  • asrf
    Thanks alot.
    Yes I studied this document its very helpful. I really appreciate it.
    Yes my Fs is 2.5GHz and Fmax is 10G so I have aliasing. In my new simulation I am planning to reduce my steps to
    40p so I have 25GHz sampling rate and then Fs/2 = Fmax so I set Fmax to be 12.5GHz.
    One of the issues of this simulation is:
    since I want to observe flicker noise my resolution BW should be at least 1KHz and for this I need 1mS simulation time.
    So this simulation will take very long time.
    Is this the typical way of simulating PLL ? lets say each time we need to change any parameter within loop we need to wait hours or half a day for simulation ?
    Dear asrf,
    If I understand your concerns, I've added a few comments. I hope I understood them correctly and apologize, in advance, if I have not!
    If you are using any modern MOS technology, the 1/f noise component extends to a phase noise offset frequency of much, much greater than 1 kHz. Hence, unless you have a specific interest in the 1/f noise at 1 kHz, there is no need to choose a simulation time that will allow a Fourier analysis of frequency components as low as 1 kHz. Typically 1/f noise corner for a submicron CMOS technology extend to 1 - 100 MHz.
    I might suggest you consider the application of your VCO when used in the PLL you mention for two reasons.
    1. Recall that the phase noise of the PLL output will ideally reflect the phase noise of the input reference signal - and NOT the phase noise its inherent VCO - for frequencies up to the PLL loop bandwidth. My guess is your PLL bandwidth is far greater than 1 kHz. Hence, the phase noise of the VCO at 1 kHz will be attenuated signficantly by the PLL open loop gain at 1 kHz.
    2. What is the application for the output clock of your PLL? If it is the source clock to some type of standard, there is usually a jitter requirement on the clock that is specified over some frequency range. For example, in telecommunications, a commonly used set of of offset frequencies used in its specification is between 12 kHz and 20 MHz. Hence, a filtering operation is performed on the PLL output clock using a bandpass filter between 12 kHz and 20 MHz. This will further attenuate any phase noise with components as low as 1 kHz.  Therefore, it might be worth studying the end application of your PLL to better understand what frequency range your VCO phase noise simulations must include.
    Shawn
  • asrf
    Hi
    Thank you for your time. I appreciate your time and effort Slight smile
    "Recall that the phase noise of the PLL output will ideally reflect the phase noise of the input reference signal - and NOT the phase noise its inherent VCO - for frequencies up to the PLL loop bandwidth"
    yes for low offsets its M^2 * reference PN (M= division ratio)
    "This will further attenuate any phase noise with components as low as 1 kHz.  Therefore, it might be worth studying the end application of your PLL to better understand what frequency range your VCO phase noise simulations must include."
    Its true I might not need to have ResBW below 1KHz
    Recently in 5G applications phase noise is integrated from 1KHz to 100MHz
    We can increase our steps to reduce sample frequency and also reduce FNOISE_MAX (For example 1GHz) BUT! the problem is if we have a PLL operating at 5GHz in order to run transient we need to have sampling freq at least at 10GHz right ? I would make my Fs =50GHz so then we will have high Fs/2 and high FNOISE_MAX again and in order to obtain 1KHz ResBW we need to have (1m * 50G)+1 samples !
    I was able to plot the PSD of simple noise source finally:
    It was not easy. I also took moving average to make it smooth.
    I made Fs/2 = FNOISE_MAX but I know for the best results FS/2 should be higher than 2*FNOISE_MAX
    >>>>>> Also I have learned that its better to run multiple sims and take average (at least 3)
    Dear asrf,
    From what I read, it seems to me you are making very good progress! Great!  Please allow me to provide a note or two in response to your added comments.
    However, in a 5G based synthesizer the phase-locked loop bandwidth will in general far exceed 1 kHz. From a recent paper whose reference is shown in [1], an optimum bandwidth of about 1 MHz is proposed as a trade-off between loop transient response and phase noise.Therefore, it seems feasible to be concerned with phase noise components over 10K or 100K in your PLL simulation. At these offset frequencies, you will just start to see the influence of the phase noise of its VCO on the PLL output phase noise. In a separate calculation, you can include the phase noise of your reference clock. I do not think it is feasible to simulate the phase noise of an entire PLL with a high frequency (GHz) VCO at the circuit level to establish its phase noise at an offset frequency of 1 kHz.
    I agree.
    If you can afford the simulation time, that is fine. However, as a side note, this "averaging" can also be provided inherently in a power spectral density computation.
    Shawn
    [1] Z. Berber and S. Kameche, "Influence of Loop Bandwidth Parameter on Integer PLL Frequency Synthesizer Performances in 80 GHz mm-Wave 5G Frequency Band," 2018 IEEE/ACS 15th International Conference on Computer Systems and Applications (AICCSA), 2018, pp. 1-2, doi: 10.1109/AICCSA.2018.8612879.
  • asrf
    I tried to compare transient noise with NOISE simulation
    Results are not satisfying. Although my BW resolution is around 700Hz data below 1e5 Hz is off
    Moving average makes data precise at high freq (>1MHz) however, it introduces error at lower offsets.
    Dear asrf,
    Your curve labeled "noise sim" does not appear to be the actual simulation data. It would be be best to superimpose the actual small-signal noise simulation over your transient noise PSD results. Nevertheless, even if the curve labeled "noise sim" accurately reflects the small-signal noise result, the yellow PSD results appears to be a reasonable representation of the small-signal results. The difference between the yellow and blue data at frequencies over 7 or 8 GHz is due to your choice of a 10 GHz noisefmax.
    The differences at low frequency, in my mind, are easily explained by the very few frequency points available for the low frequency range of the curve and the statistical error.
    A transient noise is a statistical simulation and hence there are bounds on the degree to which a single simulation provides a good statistical estimate of the actual random noise. In essence, your transient simulation uses a single seed to the random noise included in the simulation. Suppose you re-ran the simulation using a different seed? There will be some difference between the two PSD simulation results - neither is "wrong" but just illustrate the statistical variation.
    As a result, Cadence recommends repeating a transient noise analysis to get an estimate of the statistical error. There is an option to run multiple transient noise simulations within the Transient Noise GUI - or you can simply repeat them with different seeds.
    I do not recommend using a moving average function over frequency to remove the statistical noise. it will weight lower frequency components far more than higher frequency components and not provide an accurate estimate of the noise.
    Shawn
  • asrf
    Thank you for your support and quick response as always Slight smile
    "Your curve labeled "noise sim" does not appear to be the actual simulation data. It would be be best to superimpose the actual small-signal noise simulation over your transient noise PSD results."
    Its actual simulation data:
    I defined a noise source and ran noise simulation:
    "The difference between the yellow and blue data at frequencies over 7 or 8 GHz is due to your choice of a 10 GHz noisefmax."
    If I want to implement this on PLL actually I need up to 100MHz so 7-8GHz does not matter much.
    "very few frequency points available for the low frequency range of the curve and the statistical error."
    My BWres is around 1k so at 100k I have 100 freq points isnt that enough ?
    "There is an option to run multiple transient noise simulations within the Transient Noise GUI - or you can simply repeat them with different seeds."
    I did this before. Yes, I can run at least 3 simulation and take average PSD (My next plan)
    "I do not recommend using a moving average function over frequency to remove the statistical noise. it will weight lower frequency components far more than higher frequency components and not provide an accurate estimate of the noise."
    If I dont take moving average how am I supposed to see the exact PSD number ?
