  3. VerilogA for staircase voltage generator issue
  • Subscribers 127
  • Views 9078
NewScreenName
NewScreenName over 2 years ago
Hi all,
I am trying to generate a staircase signal for a testbench. One way would be using vpwl but if I have, say 100 or more steps, becomes unpractical.
Or I could use a vpwlf loading an external file, but in this case, after briefly searching around, it seems to me it does not support parametrized times and values (feature which I need here). In case parameters are allowed there instead, could you please point out to a reference explaining the correct syntay to be used?
Therefore the last option I envision would be writing a verilogA model to generate this, but it is not working, I think it is most probably a syntax issue? Below is the code, and the issue is that vout only gets updated for i=0, i.e. the first step, afterwards it is as if the cross( $abstime - t_start+i*stair_step_time, +1) statement did not get triggered anymore.
Which would be the right syntax?
Thank you and best regards
CODE:
`include "constants.vams"
`include "disciplines.vams"
module staircase_voltage_generator(A, B);
inout A, B;
electrical A, B;
parameter real t_start = 100n;
parameter real stair_step_time = 10u;
parameter real stair_step_amplitude = 6m;
parameter real vo_begin = -60m;
parameter integer steps_number = 100;
parameter real td = 10p from [0:inf);
parameter real tr = 10p from (0:inf);
parameter real tf = 10p from (0:inf);
real vout;
genvar i;
analog begin
  @ ( initial_step ) begin
   vout=vo_begin;
  end
  for (i=0; i<steps_number; i=i+1) begin
   @ cross( $abstime - t_start+i*stair_step_time, +1) begin
      vout=vout+stair_step_amplitude;
   end
  end
  V(A,B)<+transition(vout, td, tr, tf);
end
endmodule
    This post shows a way to do this with a clocked source to trigger the transitions:  staircase function
    You could do it with @timer instead of a clocked source - it certainly would not be done with a for loop the way you've done it - using @cross to detect time crossings is not a good idea and you are creating a lot of cross events for every iteration of the loop (I know it's a genvar). It would make more sense to do something like (I only did very limited testing):
    inout A, B;
    electrical A, B;
    real vout;
    integer i;
    analog begin
       vout=vo_begin;
       i=0;
      end
      @(timer(t_start,stair_step_time)) begin
        if(i<steps_number) begin
          i++;
        end
      end
    end
    endmodule
  • NewScreenName
    NewScreenName over 2 years ago in reply to Andrew Beckett
    Thank you for your reply, the code seems to be working fine.
    Just for sake of understanding, what is wrong with the for loop?
    There are n_steps loop iterations, each containing one cross function getting triggered once, timer function will get triggered n_steps times as well, is this correct? Where does the overhead lie?
    And moreover, a part from the efficiency point of view, why is the for loop just not working? (or actually working only for the first step) Is it not correct to assume that @ cross( $abstime - t_start+i*stair_step_time, +1) would get triggered as tran sim time passes? If not, why? cross function should be able to evaluate any expression, is $abstime not an expression maybe?
    ShawnLogan over 2 years ago in reply to NewScreenName
    Dear NewScreenName.
    I am not a veriloga expert, but when I looked at your source code, it seems that your for loop will run a single time after your begin statement. There is nothing limiting the advancement of your for loop counting integer i at a given time. Hence, it will simply complete the for loop after the begin statement and not trigger at each staircase transition time as you desire.
    In Andrew's code, the timer serves to trigger a stairstep event at each desired time.
    Shawn
    Andrew Beckett over 2 years ago in reply to ShawnLogan
    The issue is not the loop (which is a genvar loop, so is expanded at "compilation time", so is equivalent to unrolling the loop and having lots of @ cross statements, one for each expanded time. The issue is that the argument is not an "analog signal" - and so that means (I believe) that the timestep control in the simulator can't iterate to resolve the crossing point accurately because it's not a function for which the derivative can be taken. The Verilog-AMS Language Reference Manual (LRM) is a little vague on this, but it does say:
    The cross() function is used for generating a monitored analog event to detect threshold crossings in analog signals when the expression crosses zero (0) in the specified direction. In addition, cross() controls the timestep to accurately resolve the crossing.
    Possibly the compiler should object to this expression in some way, but in practice it just doesn't work and it would be an inefficient way of scheduling an event at a time - normally the @ cross event is trying to place a timepoint at the crossing point and so has to take time points near the crossing point too to improve the accuracy of the crossing, which would be unnecessary for something that is just a timed event - which is why the @ timer is a more appropriate way of doing this.
