  3. Design Intent questions
  • Views 8857
StephanWeber
StephanWeber over 3 years ago
we plan to adopt this feature, and have the RAK, but several questions popped up on how to use it:
1. There is a feature to define a circuit half, to let it match to the other half. This is nice, but what to do with shared devices like the current source of a diffpair, or the input transistor of a current mirror.
In the RAK these devices are kept out, but this way the layout can be still have a bad asymmetry if e.g. the input current mirror transistor (or a diffpair current source) is not in the symmetry line!
2. I see you can use Design Intent for high-current designs, but can I also set to require a certain max net capacitance? This would be helpful for all kind of very sensitive circuits or RF designs.
3. Will I get a report on violations, if if the layout is not 100% symmetrical, how much routing R and net cap asymmetry I will get (unfortunately)?
4. Can we use DI to define or check e.g. on pin currents?
5. Like 4: Can DI help to check on transistor operating regions?
Bye Stephan
    Hi Stephan,
    Please follow this up with customer support.
  • StephanWeber
    StephanWeber over 3 years ago in reply to Andrew Beckett
    Thanks, Andrew, will do so. Looks that we will use DI in our company only for few more specific things.
