  3. How to compare the before and after extraction values of...
  • Replies 8
  • Subscribers 136
  • Views 11642
How to compare the before and after extraction values of resistance and capacitance?
Vishesh Gupta
Vishesh Gupta over 3 years ago
I made a layout of a circuit which has a capacitance used in it. The capacitance used is a nmos capacitor. Is there any way I can compare the values of this capacitor before and after extraction (maybe a table that I can get)? I also want to know how the algorithm in the software has treated the capacitor? In other words, does the software breaks the capacitor in a pi network or star network, etc. in the extracted view.
Thanks and Regards,
Vishesh
    ShawnLogan over 3 years ago
    Dear Vishesh,
    A common method to compare the effective impedance of a schematic view and layout based view (extracted view) is to perform a large-signal or small-signal impedance simulation and print or plot the results. For a non-linear capacitor whose capacitance varies with DC bias, a large signal impedance simulation might be best as it will indicate the effective capacitance for the amplitude and bias values you apply in your simulation. For a fixed capacitor, a small-signal impedance simulation might be more appropriate.
    For your reference, I have provided a test bench and means of estimating the C-V characteristics of an arbitrary circuit at the post:
    community.cadence.com/.../capacitance-vs-bias-voltage-curve-for-ferroelectric-varactor
    I also included the expressions to compute the effective capacitance and real impedance of the device under test. Perhaps this will provide some insight into estimating the effective output capacitance of your device.
    Shawn
    If the capacitor is an nmos capacitor, then the parasitic extraction is not doing anything. There's no algorithm to apply here - what would happen is that your LVS tool will recognise the device, measure various parameters (such as drain/source areas and perimeters, LOD effects, Well proximity etc) and then these appear in the extracted netlist.
    Parasitic extraction tools extract interconnect and may indeed generate a set of distributed RC (fracturing the interconnect based on length, change of layer, etc - some of which is under user control) - but that's not what is going on here (and exactly what it does is dependent on which extraction tool you're using, and the precise algorithms are likely to be proprietary; most will use some pattern matching based approach, but may use field solvers for more accurate capacitance extraction where needed).
  • Vishesh Gupta
    Vishesh Gupta over 3 years ago in reply to ShawnLogan
    Hi Shawn,
    Thanks a lot for the reply!
    I will try your suggestion and update whether it worked for me or not?
    Vishesh
  • Vishesh Gupta
    Vishesh Gupta over 3 years ago in reply to Andrew Beckett
    Thanks a lot for the reply! Your information is really helpful.
    Q1)
    Will I be able to see the capacitance of the device in the parasitic extraction netlist and will it be included with the other cap parasitics list or in a sperate list?
    Q2)
    I want to learn more about the "fracturing of the interconnect", can you please help me with something?
    Vishesh
    Andrew Beckett over 3 years ago in reply to Vishesh Gupta
    As I said in your other post, this depends on whether the device is modelled by specifying the w and l (which I would expect) - it may be that the actual capacitance doesn't appear in the netlist; I can't answer that as it depends on your LVS rules and design kit.
    On the Quantus form, click on the Extraction tab. it's the Max fracture length field - so hit the Help button and read the documentation on that.
  • Vishesh Gupta
    I got the following:
    I know it is silly but can you please help what am I doing wrong here?
    Vishesh
    After using the Help button, use ctrl-F and search within the box at the top right of the page. This willl search within the page, rather than the search box at the top which should search the Quantus documentation (not sure why it's not). but really searching within the page should be sufficient.
  • Vishesh Gupta
    Thanks a lot!
    Vishesh
