  3. Save certain waveform after simulations end while preserving...
  • Subscribers 136
  • Views 9442
Save certain waveform after simulations end while preserving corner order
Zaara
Zaara over 3 years ago
When I save a waveform across corners, the order is changed, how to automate saving of some waveforms after simulations end, moreover preserving corner order.
  • Zaara
    I simulated TT corner across frequency and temperature, when I save from Viva through export function the corner order is changed randomly.
    Andrew Beckett over 3 years ago in reply to Zaara
    Please clarify what you're doing, the version (sub-version) you're using, and exactly what is wrong. What format are you exporting to? What order is wrong  - maybe some pictures would help?
    It's pretty unclear at the moment.
  • Zaara
    Zaara over 3 years ago in reply to Andrew Beckett
    I saved a waveform from Viva into csv format. In maestro view I can see the corner order like this typ 1G, typ 2G, typ 3G but when I save it with Viva--> waveform --> export the order in csv output file changes to typ 2G, typ 3G and typ 1G
    ShawnLogan over 3 years ago in reply to Zaara
    Dear Zaara,
    If you want to automate the process (which will avoid using the Export menu in ViVA), there is a article at URL:
    https://support.cadence.com/apex/ArticleAttachmentPortal?id=a1O3w000009TM7TEAW&pageName=ArticleContent
    which details a method to save a set of waveforms from a corner simulation into a single file. Please refer to case 2 in the article. In this fashion, you can specify the column order of the signals you wish to save in the file and the save process is automatic following the simulation.
    Shawn
