  3. Spectre warning: there are some nodes and instances from...
  • Views 9379
Spectre warning: there are some nodes and instances from the netlist topology check.
ppptt
ppptt over 3 years ago
Hello everyone!
When I complete the layout of a cmos inverter and try to implement the post-simulation of it, there is a warning:
It reminds me that some instances (source and load) and nodes are dangling and removed during the simulation so that no waveform generates after the simulation, but the pre-simulation is normal.
This is my circuit:
I wonder what causes it and if there is a method to solve it.
Thanks in advance for any ideas on how to best overcome this problem!
Maioca
    It sounds as if something is seriously wrong with the post-layout extraction - it suggests that the internals are not connected to the pins. What extraction tool are you using? What format are you extracting to - and have you checked the netlist to see if it all looks OK?
    Contacting customer support is probably the best option here.
