  3. MC stuck in ams simulation
  • Subscribers 136
  • Views 8082
sjwprcker
sjwprcker over 3 years ago
I have a tran sim using ams simulator with Monte Carlo sampling. There is only one clock generator written in verilogams creating a digital clock as
`include "constants.vams"
`include "disciplines.vams"
`timescale 1ns / 100ps
module clk_vams (clk, freq_1e6);
input freq_1e6;
output clk;
electrical freq_1e6;
reg clk_int;
real freq;
initial clk_int = 0;
always begin
freq = V(freq_1e6)*1e6;
#(0.5e9 / freq) clk_int = ~clk_int;
end
assign clk=clk_int;
endmodule
This code works well in normal simulation, but not work in MC simulation. The log shows that simlation is stuck at beginning (time = 0) without reporting any error.
My spectre version is 21.1.0.664, isr16, and xcelium version is 22.03-s001.
BR
    ShawnLogan over 3 years ago
    Dear sjwprcker,
    How is this failure mechanism different than your post 7 days ago at URL:
    https://community.cadence.com/cadence_technology_forums/f/custom-ic-design/57605/ams-simulation-within-mc
    It appears to me your tool versions are identical and the failure mechanism is identical.
    Andrew responded to that post and suggested you might contact customer support.
    Is there something I am overlooking that warrants a second look?
    Shawn
    Andrew Beckett over 3 years ago in reply to ShawnLogan
    Thanks ShawnLogan, I agree it's the same problem just with a little more detail.
    I managed to quickly reproduce the problem, but I have no idea why this is failing and I didn't find any similar issues, so the recommendation remains the same - contact customer support as this will almost certainly need to go to R&D to investigate further and find a fix.
