  3. Liberate: Characterize integrated clock gating cell
  • Views 9558
djupdal
djupdal over 3 years ago
Hi.
I have just made a clock gating cell and would like to characterize it with liberate.  However, liberate does not seem to understand it is a clock gater (resulting .lib does not include "clock_gating_integrated_cell" anywhere).  Is there anything extra I need to do to characterize a clock gating cell, or should it work just like for any other cell?  Other cells, like NAND, NOR, FF etc are all correctly identified automatically when I characterize them.
Are there any examples I can look at which include clock gating cells?
Best regards, Asbjørn
  • Guangjun Cao
    Guangjun Cao over 3 years ago
    Hi Asbjørn,
    'clock_gating_integrated_cell' attribute can be added using set_attribute command or defined in a user_data file. Since it does not affect the characterization or is not simulation-related, Liberate does not automatically add such attributes.
    Guangjun
  • djupdal
    djupdal over 3 years ago in reply to Guangjun Cao
    Thanks, that was helpful.
    I don't get any function specified for the output pin either.  Is that also something I should specify myself?
    I will do another characterization of my library now and see if I can get genus to recognize the clock gating cell when I specify the attribute manually.
    Asbjørn
  • Guangjun Cao
    Guangjun Cao over 3 years ago in reply to djupdal
    clock-gating cells have a list of attributes at cell and pin levels. All need to be defined by users.
    Function of such cells is described by a statetable at cell level and state_function for output pins.
    Please refer to Liberty User Guide that has some examples. if you already have a reference library, write out the user data file will the simplest way.
    Guangjun
